Serpent 720
Old 07-09-2007, 09:43 AM
  #2701
The Teacher's Avatar
Trader Rating: 62 (100%+)
I seem to be having the same problem as Killa G. On right hand turns my car has a nasty problem with the a$$ end wanting to come around. It only seems to happen on exiting the corner on power. Initially I though it was a problem with the droop or may something not built correct. After changing everything (one thing at a time) I have yet to solve the issue. I've even had Brandon Hess (local Serpent fast guy) look at the car and....nothing I need help!!! Has Serpent ever had a problem with the plastic molds or chassis being out of tweak......I know this is probably not the case but at this point I just need a solution.
The Teacher is offline
Old 07-09-2007, 09:57 AM
  #2702
Gael L's Avatar
Are you running the lcg chassis? For some reason I believe my problem may be the new lcg chassis. Not sure if it is tweaked or if the fact that it is lightened and I have taken weight away from the bottom that I have to put additional weight back on the bottom in the correct locations. When I added chassis weights to make weight in the past I believe the problem was less but not cured. I get the impression that the new serpent hop ups for the new LCG SPP chassis such as the brass battery tray may help to cure this problem. I could be wrong but I know the team guys will steer me in the right direction .
Gael L is offline
Old 07-09-2007, 10:07 AM
  #2703
I do not think it is a chassis thing. If it is teaked, maybe, but not just the weight. Maybe you have a problem with the drive train. maybe a cvd or dog bone issue. Maybe a belt issue. Something with the drive train is most likely your problem. Check your out drive, cvd's, dog bones, pulleys, belts, etc. Also check sway bars front and rear for issues.
Hope this helps,
DJ Apolaro
dj apolaro is offline
Old 07-09-2007, 10:13 AM
  #2704
Gael L's Avatar
Hope this helps,
DJ Apolaro
Drivetrain seems good. I do have new CVD's in the front but I may also do a belt change all the way around. The side belt I just changed but the front and rear I have not changed. I am going to take the chassis off as well and make sure it is completely flat.
Gael
Gael L is offline
Old 07-09-2007, 10:22 AM
  #2705
I have had this problem every since I purchased the car. I ran the car first with the stock 4mm chassis and it would spin out. I then put on the LCG chassis to see if that would solve the problem and the car is still spinning out. I will be doing a total rebuild on the car this week so I will check the belts pulleys and diff. Hope I find something....
Old 07-09-2007, 06:16 PM
  #2706
rcabj's Avatar
Droop
hey thanks, btw for a smooth track and good traction what is the basic droop setup , and for a 130-150 long straight what spur pinion gearing is recomended
rcabj is offline
Old 07-09-2007, 06:29 PM
  #2707
rcabj's Avatar
Originally Posted by Pyramid
Something to share and assuming you meant pushing exiting corners ON FULL throttle. It was exactly what I experienced first time driving the car, box stock setup (1way) with 37s all around back in 2006. It was also on a race day. I was (actually Rene did) adding more rear toe in (about 1deg, total -3) and solve it. Surely other setup changes (as suggested) could be made to get where you want the car to be.
S720 seems 1step ahead in design till now eventhough almost a year old already. The one I like the most is that when you change rear roll center (lower arms), trackwidth will remain the same. Not all car design (maybe none in 1/10?) putting attention to this small detail.
yeap u assumed right...pushing exiting corners on full throt. simple cure u got there, thanks. i have d u'standing that more rear toe would give more rear grip and less straight line speed...
rcabj is offline
Old 07-09-2007, 07:09 PM
  #2708
0 or +1 in front and 5 in the rear. What motor for the gearing and what size tires do you use.
DJ Apolaro
Old 07-09-2007, 07:11 PM
  #2709
roadrage's Avatar
Trader Rating: 14 (100%+)
i do know that with the new LCG chassis your droop should be one number less on front and rear do to the milling out of chassis. for example on stock chassis if you ran 0 front and 6 rear on the lcg you should run -1 and 5.
roadrage is offline
Old 07-09-2007, 07:13 PM
  #2710
rcabj's Avatar
DJ Apolaro
i am running the TZ3, my tyres 61 fr and 62 rear...
rcabj is offline
Old 07-09-2007, 07:14 PM
  #2711
Gael L's Avatar
DJ Apolaro
In terms of droop should you run more or less droop when the traction is high and the track is semi smooth? Or does it depend on the rest of your setup? I believe I read that more droop less stable but more responsive?
Gael L is offline
Old 07-09-2007, 07:19 PM
  #2712
17/60
22/56
Old 07-09-2007, 07:20 PM
  #2713
I depends on the rest of your set-up. When the track is smooth and I have plenty of rear traction. I run less travel in the front, typically.
Old 07-09-2007, 09:23 PM
  #2714
THeGame's Avatar
I seem to be having the same problem as Killa G. On right hand turns my car has a nasty problem with the a$$ end wanting to come around. It only seems to happen on exiting the corner on power. Initially I though it was a problem with the droop or may something not built correct. After changing everything (one thing at a time) I have yet to solve the issue. I've even had Brandon Hess (your daddy) look at the car and....nothing I need help!!! Has Serpent ever had a problem with the plastic molds or chassis being out of tweak......I know this is probably not the case but at this point I just need a solution.
Tom check your front track width to make sure your dog bones are not binding the front end up . What are you running the front end at?
Brandon
THeGame is offline
Old 07-09-2007, 09:31 PM
  #2715
rcabj's Avatar
17/60
22/56
TQ
rcabj is offline
