Serpent 720
#2296
Originally Posted by GHETTOTEACHER
and not try to put it in the wall, it will finish everytime.
#2297
This track is just minutes away from the Nation's Capital
RC Pro Series two-day race entry form
Can be submitted at the track on race day.
Capital Classic June 6th-10th
Factory drivers already registered. 160 max. entries. Don't miss this one!
#2298
Front & Rear drive
Hi, this looks like a stupid question but I am a bid confuse with the front & rear Drive.
If you have an Over steer on throttle getting out of the corner (I need to increase rear traction).
Should I increase the rear drive to solve this, I know of other ways I can solve this problem (I have solve it at the moment), this is really just to understand the principle of rear & front over drive so in the future I can used this to solve under or over steer.
RCPANAMA
RCPANAMA
#2299
#2300
RCPANAMA
RCPANAMA
#2301
Originally Posted by Winner's Circle
If you are loose coming off of a turn under throttle then you are probably overdriving the rear too much. A larger front tire or smaller rear or both will stop the car from being loose off of a turn. But like everything in racing the more overdrive to the front the less high speed on-throttle steering you will have.
If I need to correct an Over Steer condition, can I solve it by installing the 18T front Pulley and the two side pulleys to be 22T with a 1.5mm difference between the front and rear tire will give me a 1.61% more rear drive if I go to 3mm tire difference this will give me a 3.93% more rear drive.
Will the use of the 18T pulley correct the Over drive condition by increasing the rear drive ?
RCPNAMA
#2302
Ok thanks for your answer, let see if I understood:
RCPNAMA
RCPNAMA
#2303
Rear Stabiliser Bar
Hi Guys
Has anyone tried any of the 2 upgrades to the rear stabiliser bar? One is a 2.3mm thick bar and the other is very similar to the 960 bar?
If you have, did it make a huge difference to the handling when compared to the original bar?
Acid
Acid
#2304
Originally Posted by Acid
Hi Guys
Acid
Acid
#2305
I tried all different types of bars.
2.5, 2.3, adjustable (also Mugen, Kyosho,...)
The best solution (also for different tracks) is the 2.3mm optional one.
It makes the car much more easy and stable...this all without loosing steering!
Try it :-)
BRG
Daniel
Team Serpent
Try it :-)
BRG
Daniel
Team Serpent
#2306
paolo check your PM......
Mike
Mike
#2307
Mike
Mike
#2308
Hi Guys
Acid
Acid
At first it was way to hard but then I grindet it so that it was softer. Since then it worked really well. But you have to use the base part from Serpent (it is not as thick as the 3Racing one) or grind the base part also.
#2309
Originally Posted by Andy who?
Let the conspiracy theories..........begin!
Indeed. Serpent is building it's Electric/Nitro already with Jeff Cuffs and Blackstsock would be a nice addition!!!
#2310
Hi Guys
Acid
Acid
Acid, check out Ruud Schuitmakers car...
