HELP! Cant Get Screw Out
#17
Losi as well as many other manufacturers use the reverse screw only on this 2 locations mentioned. Reason being with the suspension movement, those screws if it weren't reversed thread, usually backs out on its own. Many other manufacturers still use the regular screws so props to losi on including it in their rtr as well. Should've been noted otherwise tho.
#18
put a small shaft thru hole on other side and try unscrewing that way push as you unscrew..losi uses not thread lock on plastic..
#20
