HELP! Cant Get Screw Out >
Like Tree4Likes
Old 03-13-2017, 08:09 PM
Default HELP! Cant Get Screw Out
Hi Everyone,
I was tearing down my new buggy (Losi 8IGHT Buggy RTR) and the screw that holds the rear shock on the arm is not backing out. It just turns and turns but its not backing out. THere is nothing holding it on the thread end like a nut or anything, just wont come out. The other side comes out just fine
Evoking1230 is offline
Old 03-13-2017, 08:26 PM
KA2AEV's Avatar
Try using a pair of needle nose pliers (or other pliers that you can comfortably grab the head with) grabbing the head of the screw while you spin it out you pull on the head
with the pliers! Sounds complicated, but its not!
Let us know how you make out!!!
KA2AEV is offline
Trader Rating: 127 (100%+)
If the screw is black, then its Reverse thread...turn other way. This is only on the left rear and the front right. Losi reverse thread screws are black....I think. Lol
Jerm13 and Sinn1612 like this.
Neesh is offline
Old 03-14-2017, 06:53 AM
Jerm13's Avatar
Trader Rating: 36 (100%+)
They are....and should be installed in the right front and left rear of the vehicle. I say "should" because I have seen some on the opposite side but that is not correct.
Neesh likes this.
Jerm13 is offline
Old 03-14-2017, 09:25 AM
WTH, who does that!??! lol
Well that explains it.
Sorry guys for being such a noob to Losi (1st one)
Now I have to go buy a new screw because this one stripped, after the fact
Old 03-14-2017, 09:49 AM
Jerm13's Avatar
You're probably going to need a new arm as well...
Jerm13 is offline
Old 03-14-2017, 09:52 AM
DOH!
Old 03-14-2017, 09:55 AM
And for the life of me I couldn't figure out why one side was a black screw, and the other a silver screw....now I know. Good grief. They should mention that in the manual. And yes I read it, and no it was not in there
Old 03-14-2017, 11:33 AM
kinda of backwards but what do you expect from LOSI. They make decent kits, but mickey mouse everything else. What I don't like is if you need something like a gasket for say your engine back plate, you just can't buy the gasket / o-ring you have to buy the entire assembly. Just saying....
NitroJunky721 is offline
Old 03-14-2017, 12:04 PM
Ran home at lunch time, nope, dont need a new arm, new screw....DEFINITELY
Old 03-14-2017, 12:06 PM
I've done R/C for quite a few years and took a break, definitely not new to it, but I also expect to learn a lot as well as I don't know everything. (electric I have no clue on but that might be my next kit) I was not aware of this so I have no problem chalking that up under learning something new everyday
Old 03-14-2017, 12:32 PM
What is Mickey Mouse? What engine are you referring too? The only one I can think of is the 350. Most of the parts have been discontinued for this product, but GS hobbies have the gasket set in stock. There many not be many out there, but they have them in stock.
The reverse threaded screw has been a part of the TLR 8ights since around 2009 with the 2.0. This is noted in the last two manuals I believe. Before the left hand screw, they used a special screw with a notch in to and used a set screw in the bottom of the arm to hold the screw in.
token is offline
Old 03-14-2017, 01:03 PM
The 3.4 motor is what I'm talking about. You need a smaller part you have to buy the whole assembly. I think its a joke the way LOSI markets their products that way. With TRAXXAS you need an O-Ring set you can buy one without say having to buy a backing plate or carb or whatever the case may be.
Is there some kind of reason for this or are they just backwards. Lets throw a monkey wrench in the mix. I'm only stating the obvious. Maybe they do it that way hoping you will strip the screw and part forcing you buy a new one.
Old 03-14-2017, 01:10 PM
Losi as well as many other manufacturers use the reverse screw only on this 2 locations mentioned. Reason being with the suspension movement, those screws if it weren't reversed thread, usually backs out on its own. Many other manufacturers still use the regular screws so props to losi on including it in their rtr as well. Should've been noted otherwise tho.
token likes this.
Neesh is offline
