Starter Box metal contact points
Have anyone upgraded their starter box contact points. I think its like a copper plate that touches another copper plate.
Any upgrade ideals for this? Mine have been wielded together over time.
Same here
Had to take my Ofna box apart week before last and burnish the contacts. Noticed then they were really thin material, and probably won't stand up to a second burnishing. Battery is internal 12vdc gel cell.
Got a replacement kit on my wish list, but having second thoughts now. I'm going to try buying some brass flat washers from the local Home Depot. May have to fit them, but they're thicker and should flow current better and longer.
'AC'
'AC'
Put a capicitor over the contacts, it will take away the spark
http://www.allaboutcircuits.com/vol_4/chpt_4/2.html
Hi,
I've modified my starter box with an automotive electromagnetic relay (70A). The copper contacts only switch the relay on and off, so the high current goes through the relay. Never had an issue with burnt or welded contacts. The relay is mounted in a socket, so it's easy to replace in the case of malfunction.
Circuit diagram:
Translation:
M - electric motor
Schalter - main switch of starter box (power on/off)
Taster - momentary switch (the weak copper contacts)
Akku - battery (I use 14.8V 4S hardcase lipo)
The numbers in the diagram reflect the four relay contacts. This is standard numbering in Europe for automotive relays, don't know how it's in the USA.
Circuit diagram:
Translation:
M - electric motor
Last edited by DrNitro; 10-21-2016 at 07:46 AM. Reason: added translation for diagram
I bought some Trinity battery bars a couple weeks back for this very topic. Unfortunately we've had a couple consecutive rainouts, so I've hadn't had to mess with them yet. My thought is the higher quality material should withstand better than the garage washer and copper pieces that come with the boxes. I'll try to get to it this week.
A smal reed switch (glass magnetic switch) in a small coil acts like a current detection on the clowplug. Switching a realais what will power the startermotor.
It was directly a plug good/fail detection.
