The new rc8 is coming
#46
CR8 prototype wasn't full metal chassis like new AE 1/8 is
#47
I suspect that he was referring to the component layout. I'm sure that Josh was able to make a few improvements since the CR8 broke cover almost 3 years ago.
One thing I'm curious about though: when the CR8 was initially rolled-out, Hara-san tried it and indicated (rather publicly) his preference for the D8. I wonder if that was down to the car not suiting him, or whether there were already early signs that there were financial issues at Hot Bodies?
#48
What is the difference? When a car is better, a car is better, it doesn't matter the driver skill level, we would see their results on the track, pros feel exactly the same way when they get an easy or hard to drive setup, they talk abou it every time they race, "ohh I had problems my steup was too aggressive/smooth etc"
Just drive what you want and dont let manufacturers brainwash you with every trend
#49
The wider chassis distributes the weight over a wider area and doesnt concentrate it all in the middle like the narrower chassis's do and I think this makes them more stable turning especially and the narrow chassis's can just randomly roll over in a tight bumpy corner i found where as the wider chassis is more forgiving...of course other factors have a bearing as well like droop.etc.
#50
#51
There is no better or worse! If you like "Narrow" chassis characteristics, then you will more than likely produce your fastest laps with a narrow built car....If you like a more "lazy" feel, maybe not so aggressive feeling car then a wide chassis car will prob work best!! Not to say Hara or a pro cant win with both cause they can............But he wants to be comfortable on the stand! n he publicly says some cars are to aggressive for his style of drive.....So it comes down to driver preference........Boots n his WIDE "kyosho" lose all the time! any given day either can win.......I mean for example last year same race same people he totally dominated in qual n WON Montpilliar, this year he barely made top 10qual.......just run the car that looks best to you, with the best support in your area n you will be happy! A few months ago Agamas were going for $150 new on here!!lol the stock is prob slowly rising cause Bloomfield is proving that "he" can win with that design!! (notice I said he) lol!
#52
Love the way it looks. Front hub/kingpin/stud seems interesting, and the front hub carrier also has an inner stud mounting hole, more traditional.
Agreed, i think that's even more impressive considering Yannick's not as focused on racing as before. He doesn't practice as much, doesn't race as much, and he got the car this week!
We'll see how the Ryan's do next week!
+ YouTube Video | |
#53
+ YouTube Video | |
#55
quite frankly the MP9 is a "old outdated platform"(according to most other fanboys of other brands) but it seems to be the only car that can be setup on both sides of the field and right in the middle making it one of the best cars. - wide chassis.
#56
I suspect that for those of us who are mere mortals, narrow vs. wider chassis is much, much less of a factor than picking the right tire, compound, and then competence in terms of fine-tuning. From my limited but direct experience, wide/conventional cars DO make things a bit easier in terms of maintenance, though.
That being said, I think it's only reasonable to think that Associated wouldn't have brought out the new car if it didn't have some sort of performance advantage over the 8.2.
#57
a wider chassis has a lower CG, also when equiped with +1 mm/+2 mm option wheelhubs
as the weight is distributed over a wider area, the CG drops, so the car will be easier to drive
#58
available by May..
#59
