Old 10-29-2012, 12:14 PM   #1
Panda-PR's Avatar
Default Front tire balloning
Hi, on my xt8:
Diff: 5 f / 10 c / 3 r
I have a lot of front tire balloning and the truggy pushes a lot when off power. Which way to go? Was thinking on going thicker on the center but it may push more? Suggestions!
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 10-29-2012, 12:50 PM   #2
pickle311's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Panda-PR View Post
Hi, on my xt8:
Go thinner on the center, will turn better too. I ran 7/7/5 and 7/7/3 on my XT8
Thanks to my sponsors and friends
RC America l Xray l Hudy | Pro-Line |KO Propo | Avid | VP Powermaster
pickle311 is offline   Reply With Quote
Old 10-29-2012, 01:35 PM   #3
Panda-PR's Avatar
Will try. Thanks
snake pit:
Old 10-29-2012, 03:34 PM   #4
nitroexpress's Avatar
If the fronts are ballooning, do not go lighter on the center diff.
http://www.petitrc.com/Tech/XRC_GearDiff/article.html
nitroexpress is offline   Reply With Quote
Old 10-30-2012, 08:56 AM   #5
Zerodefect's Avatar
One front tire balloon? Thicker front diff fluid.
Both front tires? Thicker center.
Sound like your suspension settings are all wrong. Xt8's don't understeer off power. Maybe you're way too soft, low, or not enough droop in the rear. Wrong tires, too much rear toe in, too little front toe out, not enough rear camber, stiffer rear swaybar.
10/10/3?
Zerodefect is offline   Reply With Quote
Old 10-30-2012, 09:40 AM   #6
Frank L's Avatar
Trader Rating: 148 (100%+)
Thicker in the center will reduce the ballooning and thicker front will let the rear slide around more and decrease the push. The above 10-10-3 sounds good to me.
Old 10-30-2012, 09:44 AM   #7
Panda-PR's Avatar
10/10/3?
Going to try thicker on the center (15k from 10k). Its just that off power I feel that it keeps going thats why I tough that thicker on the center would make it worse. Maybe a glitching servo or some air getting from the fuel line and keeps the revs high... will verify this. Also ordered swaybars to play with.
snake pit:
Old 10-30-2012, 09:49 AM   #8
Panda-PR's Avatar
Ok.agree
So from 5-10-3 go to 10-10-3
Or 10-15-3 ? So it addresses the front tire balloning?
snake pit:
Old 10-30-2012, 12:02 PM   #9
Zerodefect's Avatar
Start with 10/10/3. That way all you have to change is one diff. And if you need 15 in the center, thats just a 20min change on raceday.
after 10/10/3 I'd look at suspension setup.
Don't fear thick fluid in the front diff. It deosn't usually hurt turn in as much as it helps exit steering.
Old 10-30-2012, 02:01 PM   #10
Panda-PR's Avatar
Will do, thanks
snake pit:
Old 10-30-2012, 07:39 PM   #11
hustler777's Avatar
Send a message via MSN to hustler777 Send a message via Yahoo to hustler777
Make sure your servo saver is tight as well...
Sometimes you gotta go back to come back...
hustler777 is offline   Reply With Quote
Mugen MBX6T Mugen9112 Nitro Off-Road 8494 04-12-2017 12:03 PM
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread SaladFork Electric Off-Road 46468 03-20-2017 08:56 PM
E-Truggy The next big class!!! flysullivan Electric Off-Road 1952 07-23-2015 12:57 PM
O'donnell Z01T setup DNO Nitro Off-Road 9 08-26-2009 09:42 AM
