What is this???
What is this???
i was looking at pics on neobuggy from this years montipellier and i came across this picture of mayfields buggy. what is he using on his pressure line?? is it a one-way vavle?? If so why
My old eyes can't see it on that image, but there are generally two items that some people use on their pressure lines:
1. Exhaust cooler -- an aluminum or steel heatsink (that looks like a fuel filter) which in theory cools the hot exhaust before it gets to the fuel tank. Hot exhaust = hot fuel = worse fuel economy. Some people also used to use a fuel filter without the filter element for this purpose
2. Pressure valve -- Orion introduced one of these a few years ago -- not sure if there are more on the market now. It basically helps maintain the pressure in the tank, even when the car is upside down.
That gold color piece near the tank cap?
It looks like a fuel line coupling adapter, maybe it has a smaller hole to lower down the pressure. I have played with lowering the pressure and must say that you can make some improvements with that.
Here are some links to bigger pictures.
http://gallery.neobuggy.net/2012Race.../O/DNC0177.jpg
http://gallery.neobuggy.net/2012Race.../O/DNC0182.jpg
Zooming in on the 1st pic I would say I am right. With setting my IE zoom on 400% I do see a smaller hole in the coupling piece.
ok so i have heard of using valves to increase pressure and have heard nothing but bad things but i have to admit i have never heard of lowering your pressure . what are the benefits?
Lowering pressure will fiter out those boosts giving a less rich bottom end without going to lean.
The engine will be less pressure sensitive. Going back from top rpm to idle in a normal situation will still give a pressure boost resulting in a rich bottom end when giving throttle again. Trying to lean out can give other problems.
Ik do not know what parts, such things can smple be made by yourself.
Therte is one thing you can look at, there are some exhaust gas coolers wit a HSN from a carburater attached. With that you can adjust the pressure.
