After run oil: who uses it?
#16
#19
Can't hurt anyway. Better to be safe then sorry.
#21
rbmods oil is thick, it is the best stuff as far as ARO , its semi synthetic , safe for silicone cranks and is not that hard to start up . tip: prime your engine before starting up by blowing on the pressure line and holding the carb open
the reason why it is suggested to run all the fuel out is because there are corrosive properties in the nitro methane and methanol that is in the fuel . this will in the long run shorten your bearing life drastically
RB mods ARO if you are gonna run the engine within a few days its ok to not insert ARO in the engine , if it is gonna sit for more than a few days use ARO tip : leave your engine sitting with the front of engine pointing down ( trust me )
stop engine by flywheel unless you like to replace your front engine bearings more often then needed
also that engine slick stuff that rick sells works badass!!!!
no i am not sponsored by rick i just know good products
#22
rbmods oil is thick, it is the best stuff as far as ARO , its semi sunthetic , safe for silicone cranks and is not that hard to start up . tip: prime your engine before starting up by blowing on the pressure line and holding the carb open
the reason why it is suggested to run all the fuel out is bescause there are corrosive properties in the nitro methane and methanol that is in the fuel . this will in the long run shorten your bearing life drastically
#23
#24
+1 one that. If its thin i wouldnt use it. It sounds like a horrible air filter oil to me. You want something that is thick and sticky for an air filter oil.
#26
#27
Hey, maybe it will work as both, but I personally would never use it as both. Just my opinion. ARO should be thin to coat things well and not gum stuff up. Air filter oil should be thick to keep fine dirt out of your engine. Again this is just my opinion gathered from my experience running nitro engines.
I don't run the fuel out of my engines because doing so will burn off any fuel left in the engine and lines, and basically starve the engine of lubrication. You are essentially running your engine extremely lean, even if only for a very short period of time, it is not good for your engine.
I run Odonnell fuel. Have never run my engines completely dry intentionally(unless they ran dry while running on the track), and have had them sit for months without any ARO coming near them. Yet when I open them up, they shine internally. Not one little spec of rust on anything. Bearings, crank, etc... completely rust free. I run ceramic bearings in all of my engines so I don't worry about the balls themselves corroding. No carbon build up on anything, and they always fire up first try.
So I will say again, my opinion is that ARO is not needed, and running your engine completely dry can only cause issues. Again this is MY opinion and I am entitled to it, as you are entitled to yours. I will continue to do what is working for me. My engines run strong, last long, get great fuel mileage, and fire right up every time. So as I say, I will continue to do what I do.
#29
I race alot, hardly ever use the stuff, It may come in handy if you need to store a mill for months, I do use it if, I park a broke in mill, seems to be worth it, I get 8-10 gallons on a race engine, sometimes more, I have a GRP .21 that I began racing in Feburary of 2008, still running fine, it may have seen afterun oil once, I will be running this mill again this weekend. It currently has a screwed up clutch bell, cause my mounts came loose in the main(My stupid neglect) It has seen alot of fuel, Byrons gen II, Sidwinder, Torco, and White Lightning, still motering on, race on the Weekend, no fuel run out, no oil, fires up on demand.
#30
cold fusion after run oil is all i use
