What Clutch Bearings Do You Use?
#46
0.5mm is on the "slightly too much" end of the spectrum
End play is just there to offset any thermal dilatation and parasitic movement, really... 0.2mm (ie slightly less than 1/100th of a inch) is pretty much all you should need.
As said earlier, it's as much in the bearings as it's in the clutches themselves
Paul
Paul
#47
Paul
Paul
#49
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
I just make sure the clutch bell is on the loose side. It's pretty hard to calculate how much the heat will make everything expand, and too tight will smoke bearings. I usually end up with about .5mm I would assume, maybe even a tad more. I was told to do the same thing by a couple pros who have been around the block too..
#51
sometimes the fast guys dont know everything guys
#52
#55
Well I suppose I should have asked who actually measured their endplay and didn't just guess.
One guys .3 could actually be in reality .5mm or greater. I thought the "rule of thumb" was .4-.5 but I honestly haven't asked that many people.
I use 1 dollar avid bearings and just change them out before they go bad, simply because I've had them go out on me, and had them get stuck on the crank once or twice back in the day too.
#56
#57
I run the tko special bearigs with no issues.
#59
I ran Avid Bearings and have never had a prob with them at all. Avid all the way
#60
I use a .3 shim and make sure i can stuff it in between the shim stack and make sure it can walk up and down....you only need to get the corner of the shim in the stack to get a good idea of where your at......the Kyosho shims make the job almost too easy if you ask me....and its funny how many guys have invested lots of $$ in those Crappy ofna shim kits that come with an assortment of shim's...there's really only 3-4 clutch bell shims in there that you can actually use.
