throttle/brake help
throttle/brake help
Here is the problem im having:
http://s453.photobucket.com/albums/q...t=CIMG0001.flv
When i release the throttle it closes all the way. But when i release the brake it opens. How do i fix this. lmk thanks
Did you set your EPAs?
You need to put a spring on the throttle shaft, between the ball cup and servo arm mount. The spring is like the one out of an ink pin.
You might also add a return spring.
my guess is ethier the throttle collar doesnt have enough if a gap or the idle is closed to much it could be the brake linkage setup i think that would affect it maybe
is the servo centering
lol...come on man im sure ur smart enough to figure that out...i mean its not something that people can really help u with online...more then likely the rod is staying hung up on the servo adjuster...not a big deal just sit down and figure it out....
