Piston & Sleave Question
I went to the LHS and put the truck in the shop due to I am not sure what I am doing. They told me that the piston and sleave was bad. It was sticking and the top. Is there a way to get it not to stick or is it sopose to be tight at the top? With the glow plug out and heat sink off the sleave slides up when you turn the flywheel. Can someone give me some info on this please? Thanks alot.
Heat up the motor, then try it. New engines should never be started cold. Also dont flood the engine. And loosen the glow plug 1/2 turn, then tighten it immediatly after you start it.
I usually loosen the glow plug when i am breaking in my engines....after they are fully broke in, i usually kick them off on the starter box with no probs.
your motor might not be fully broke in...as what was said, heat it up then run it, just dont get your carb too hot when pre heating your motor.
