novarossi p5x
There are many good plugs to chose from. If you plan on running 30% fuel you'll want to stick with a COLD plug. I normally run the McCoy MC-9.
There are also alot of good pipes on the market that will work well with that engine. One that makes more power than most with the P5X is the MSR 1005 but it's not cheap. It's also a little soft and dents fairly easy if you get punted on that side. The 053/9853 is also a popular pipe for that engine.
ASK HOUSTON
O.S.#8 or O'donnel 99
edit: yeah, and a JP3 is safe. I run mine with a Jp4 at the moment, works fine, hard to tell on the snow.
FYI; I run the P5X with a O.S. Vspec carb..... works GREAT!
why would you replace the best carb on the market
odonnell 77 w/ 30/11 gen2 and a dynamite 086 hs pipeset 8mm restrictor , add extra .10mm head shim if there is excessive carbon build up , you will get more top end and better run times . take my advice or not its up to you
houston
houston
houston
houston
Hey Monty do you want to play with my Hot Mod P5(done wore out). I need a back up motor for this year and if you think it would be worth fixing and making super fast I will hand it to the master!!!!!!!!!!! Is your MP9 setup still a good start for me?
houston
houston
i promote the products that i feel are the best on the market , i dont receive anything for free from anybody !
run what you are used to , i have put many nova carbs on trinity, OS and GO engines and they all ran better after doing so .
anytime pat
503 544 6624
