Brakes, Brakes & more Brakes!!! >
Old 01-16-2009, 08:31 AM
rcgeezer's Avatar
Default Brakes, Brakes & more Brakes!!!
I'm looking to upgrade the brakes on my Kyosho ST-RR truggy, and would like some advice on the best pad/rotor/caliper combinations being used out there. It seems that most of the aftermarket stuff is interchangeable, so what's working best for you guys?
rcgeezer is offline
Old 01-16-2009, 09:11 AM
"Smiley"'s Avatar
Trader Rating: 171 (97%+)
As far as Brake Discs go, You cant go wrong with the Avid Indos. They are by far some of the best out there. Check them out at Avidrc.com
"Smiley" is offline
Old 01-16-2009, 09:36 AM
pinky2252s's Avatar
Yep they are
pinky2252s is offline
Old 01-19-2009, 01:58 PM
rcgeezer's Avatar
Thanks guys, any other suggestions? Anyone using Racer's Edge disks?
rcgeezer is offline
Old 01-19-2009, 02:10 PM
PTP Racing's Avatar
I thought the brakes on the STRR were some of the best ever.
PTP Racing is offline
Old 01-19-2009, 03:24 PM
+2. Kyosho has the best brake rotors and pads. The aftermarket stuff might make your braking a little better, but that isnt exactly going to make your lap times go down substantially. The Kyosho pads are made from the same stuff as real car pads and the rotors stay true and dont wear much at all. I have never had brake fade with my 777WC, actually, they feel like they get better the warmer they got. I started braking hard during my warm up laps to get some heat in them before the clock starts.
NCWC is offline
Old 01-19-2009, 04:16 PM
houston's Avatar
Trader Rating: 96 (100%+)
upgrade from kyosho brakes ????? there isn't such a thing
kyosho makes the best brakes on the market !!!!! period
get yourself a new set of bonded acre kyosho pads and be done with it you will not find a better braking system for rccars
houston is offline
Old 01-20-2009, 08:20 AM
rcgeezer's Avatar
WOW! I never expected to get this kind of response for the stock Kyosho brake system. I must say that you've all convinced me, I'll stick with what I have. Houston, you mentioned "bonded acre" pads...what are these and where do I find them? Are they the new upgraded Kyosho pads or what?? Thanks for all the responses!!
rcgeezer is offline
Old 01-20-2009, 12:44 PM
PTP Racing's Avatar
They should have been stock equipment if you had a ST-RR. You should be able to find them in the parts listing.
Old 01-20-2009, 02:33 PM
rcgeezer's Avatar
Unfortunately no, this truggy began life as an ST-R and was partially converted before it got to me. I've completed the process but I'm still finding certain items that may have been overlooked. The pads attached the calipers seem to be pretty thick, so since the stock ST-R's are very thin I'm going to assume that they have been upgraded to the newer ST-RR version. Seem logical???
rcgeezer is offline
