8T 2.0
#5506
got mine...
the position the links are in the pics i ened up changing once i got it on the ground i dint like how the camber was set, and my links are shortened, but not short enough to give me the camber i wanted...i moved it to the lower INSIDE hole on the tower, which is the STOCK postiton like it would be on the 1st generation shock tower...
#5507
#5508
reggie, i got mine last week and i was testing it last saturday, i had my links in the "stock" location but it pushed, changed the position to where yours is in the pics and then i checked my ride height and it was off so thats why it was pushing, not the camber location. my question is how is the "stock" location with the new shock location. does it allow more rotation or push a little bit?
#5509
In those pics it looks like the right rear outdrive cup is worn pretty badly. I can also see damage to the right rear arm where the inner hinge pin goes through. If the damage is as bad as it looks in the pic this could easily be causing the problem if it's letting the arm move back and forth. The worn edges on the outdrive cup can't be helping either.
I would fix those 2 issues and try again. I have never seen/heard of this being a problem. Hope this helps man!
The first time it popped was during practice, first thing in the morning. I even put a brand new drive shaft in.
#5510
There was a post before that said cut the rear links to the front meausurement, but the part nimbers checked with losi shows they're both
107mm. So are you guys cuttin g the rear shorter and are still making the rear 142mm total length. because the directions show the front total at 142.50mm amd the rear and 142mm
#5511
#5512
Modded rear hubs
Hey TIX
Are you still doing the modded hubs for those of us downunder?
#5513
How much play should be in the rear where the pinion meets the ring? I got a new pinion and housing to replace the old one and used the ring from my 1.0, shimmed it put it still feels like it has to much play. Im new to this so i dont know if it is supposed to be this way because dont they have a break in period too? Any help would be nice.
#5514
#5515
#5517
Any good upgrades or tips i should know about? Im want to get tit. turnbukles and LW diff cups to take some weight off, but i'd rather take it all of the drivetrain if i can. I seen on a-main that you can get LW pinion and driveshaft axles, has anyone used these and are they worth the money?
#5518
#5519
The reason im asking is because there's going to be another truck setup like mine with a jpx. 28 on it @ the local track. I've already put the 48 tooth spur gear on it to try and kill some wheel spin when i take off or i hope thats what it does....
And frank, What is your setup on your truck? I seen it on another tread but cant remember which one.
#5520
BCE chassis - lighter weight than stock and greatly improves handling
http://shop.bcespeed.com/product.sc;...3&categoryId=1
Losi lightened spur gear
http://www.amainhobbies.com/product_...tial-Spur-Gear
Losi lightweight center diff outdrives
http://www.amainhobbies.com/product_...al-Outdrives-2
Losi lighweight f/r outdrives
http://www.amainhobbies.com/product_...-8ight-8ight-T
