AKA tires
#31
OMG!!!!!!!!!!!!
I have just been graced by the best looking and feeling Truggy tire set-up in my life!!
I have the first production samples of the new Truggy CitiBlock and I-beam sitting here in my desk with AKA foam (Just like the buggy) and Aka wheels!! OMG these tires are going to be the ONLY tuggy tire to have!!!!!
Look for them in mass production at the end of November hopefully!! And if your going to the R/C Pro Finals you will get a sneak peak! ;-)
#32
Ryan, will you maybe have some samples or any Truggy tires that you may be able to help out a Fellow Kyosho Driver with (Me) @ the R/C Pro Finals! LOL! J/K! I've had 5 pairs on backorder since July 5th!!! Seriously though, I do hope I get a chance to talk to you @ the R/C Pro Finals!
#33
Ryan when you say NO prep do you mean no brake clean on rim & tire bead?No sanding big chunks of flashing from either side of the bead? Let me make this as clear a question as possable,Open bags,assemble wheel,glue with no roughing or cleaning of any kind? That sounds too good to be true.Surely you mean only minimal time like 10min of prep?
#34
butch man: I can't speak for Ryan, but that's the way I understood it when I got mine & glued them up. I currently have 6 sets of these glued up & that's all I did was take the tires & rims out of their bags & just glued them up without doing any prep at all & still have yet to have any tires come unglued in any way, IMO alot of it also has to do with the fact that the inserts in these tires are so Awesome that they don't allow much carcass roll as they are firm & any/most of the roll would come from the tire itself (the nobbies), I have soft & medium compounds & have had great luck with all of them. The wear on these tires are incredible, after a qualifier & a 30 Min. main in Alabama & pretty much all this past weekend in Lafayette, LA with a set of Soft compound I Beams & still show Little to No wear. Looking at the back of the bag on these tires, I currently have 8 runs on these tires & they still look & feel great! I CAN'T WAIT 'til the Truggy tires come out, was really hoping to have all mine in before the R/C Pro Finals, but doesn't look like that's gonna happen.
#35
I friend gave my son a pair of soft city blocks to try this weekend, he was running on a small hard packed track. The grin on his face when he came off the track told me everything i needed to now, i went and bought a set today
#38
I mean yes, exactly what you said. Open package and glue. The only exception is occasionally on the Soft compound tires they will have some flashing due to them being hard to cut for the machine or whatever they use. Other than that, no prep! But I won't recommend that if you change any of the variables.
AKA tire
AKA wheel
AKA foam
AKA glue
#39
I generally run two holes in the tire. Just a standard holepunch size. They don't need to be big and you really only need one hole. They are closed cell foams and thus don't really need to 'breath' like Open cell.
#40
Ryan, what do you gain from hole-punching your tires? Equivilant to holes in the inner wheel?
-Red
-Red
#41
+1
#42
You would not want to run AKA tires without the AKA insert. That is one of the most inovative and critical parts!!!
Correct that the I-beam is the most similar to a Boe-tie.
The entire AKA package of tire/foam/wheel/glue is of course the best combination to use because the product was meant for each other. The fit and finish of each piece works together.
Of course other wheels / foams / glue will work though..
SO, if I-beams are working in the loamy then later in day track grooves alittle what tire is next? Or just what is the AKA tire order from loamy to blue groove?
Really appreciate the help! Other companies could learn some things
#43
If you are on a clay track or bluegroove track feel free to put the hole in the tire or the wheel. Personal preference then.
#44
OMG!!!!!!!!!!!!
Ryan are the wheels any different from a standard LPR size wheel? Just asking cause I don't want to stock up on the JC Half ups I normally run if they won't work..
#45
On top of that in the transition period where maybe you have hardpack underneath with just a fine layer of loose dirt on top then the Gridirons are the bomb!! Also on the Bluegroove track the Gridirons are awesome and if your looking for an hour long main tire on an abrasive bluegroove track then the Cityblocks are again the tire of choice!!
Keep the questions coming guys! These tires are awesome and everyone owes it to themselves to give them a try!
