shutting of at 1/2
what would cause the engine to shut off at a 1/2 tank??
there a couple of reasons.
air leek ( chek filters, and tank top for back pressure) running to lean and over heated. glow plug. |
runs in the 230's but im starting to think my cap is leaking, everytime i run it seems like there is fuel on the top of the tank. could that be the cause??
ya because the top on the tank has to be sealed nicley because it keeps back pressure on the fuel, and fuel wont be able to get to the engine.
how long is your fuel line and how many filters |
no filter, factory setup, i just got it
ok. than it might be the tank cap and its not getting back pressure some times and it doesn't get fuel.
also check how good the plug is and change the fuel line. the nipple that is on the tank cap, make sure that is tight. use needle nose pliers to tighten it. |
depends --- on if it's half full, or half empty .
:D |
haha good one:lol:
would it also make it so it wouldnt want to start if its warmed up, someone said something to me about clutch spring issue?
so it dies at half empty? could be a faulty tank. half full is usually at the molding line of your tank, it could have a slight crack along the molding line that would cause your tank to lose pressure as soon as the fuel went to half empty. Pressure is usually fine when the tank is full because the fuel is creating a seal at the crack, but as soon as the fuel falls below that crack, air rushes into the tank, causing all the fuel in the fuel line to rush out and your engine dies!
would it also cause a problem restarting, when at half full??
it all leads to back pressure probs in my eyes
what kind of pipe r u running |
Tank leak
What brand is it? Let me guess, Losi? They are known for this. More than likely there's a crack someplace. Take it off, plug the outlet, put some long line on inlet(the cap) put it under water and blow. It will show it's self then. If a crack you can mend it with a soidering gun and hot glue. Around the lid, just replace it. Hope this helps....:cool:
has a jp-3 pipe. also going to test the tank today. also someone mentioned to me it could be im running it to rich?
so which is it, when it gets to 1/2 a tank or when it gets warm?
