Most cost effective way to switch to lipo?
I was thinking about finally switching from my old NIMH reciever pack to a lipo set up. what do I need and what will it cost? I was thinking I'd Need the Pack itself, a charger, and a voltage regulator/cutoff.
I need the best prices, and I don't need a Duratrax Ice charger, just something good enough for the reciever pack and that's it.
I'll be putting this in my new Xray XB808. I appreciate any, and all replies.
HT Batteries has eerything you need for the lipo switch over.
rec packs
lipo regulator
charger
and if intersted they also have
transmitter packs
starter box batts
http://www.htbatteries.com/
Apogee/ pfm distribution probably has the best price on a rec pack
2000 mah 29.99
https://pfmdistribution.com/secure/s...y.asp?catid=63
Amain has a very good regulator that has a green lite if pack is above 6.2 volts and a red if it is below
Currently i have the amain regulator and protekmpack in my gt2 &
HT Batteries reg and battery in my STRR along with starter box aand transmitter pack and will be ordering the charger soon
Hope this helps--also how do you like the 808 so far--it looks really impressive although i am yet to see one run
Jason
rec packs
lipo regulator
charger
transmitter packs
starter box batts
2000 mah 29.99
Jason
+1 for ht batteries. As far as voltage regulator I love the losi one. On the charger there are several on the market and there is also a lipo convertor you can plug inline with your existing charger. I cant seem to find it right now I thought it was made by losi.
Otherwise if you want a charger that will do receiver packs this one will work but you will be limited to 2 and 3 cell packs which means that if you ever switch to a 14.8 volt pack for your starter box it wont work. It also charges fairly slow but that isnt a bad thing as long as you prepare having your packs all charged before raceday.
Here is a link to the charger im talking about although there are several on the market just like it.
http://www.amainhobbies.com/product_...ducts_id/22612
Once you go lipo you will love it. Just beware not to let your battery run dead, use a lipo specific charger or convertor, and do not exceed the charge rate of the pack. A 2000 pack should not be charged at any more than 2 amp, a 1200 1.2 amp.... You get the idea.
With the Xray, you'll must likely be limited to the HT Lipo. The Common Sense RC Lipo are great, but may not fit in the Xray slender battery box. The Losi regulator is good also, very compact 5 amp unit. I use regualtor only, not the one with the switch. As for chargers, a Celectra works fine and can be found for $30-$35 and does up to 2 amps. It has no balancing though and is DC powered like most.
Team EAM
The Pro-Teck 2300mah stick pack Lipo fits the Xray like it was made for it. A few locals here have them and its perfect. There regulator is great too. Havent heard of anyone having any problems out of either one. Amain carries them or nexusracing.net also has them for about 10.00 cheaper.
EA
EA
Going high end with the xray big dog? Sweet!!! I run HT Lipos in everything, Radio, Rec, Starter Box. I use my ice charger with a electrify balancing adapter. I can charge all batteries by just switching the plugs. It came with all the right connectors and everything. The only thing I had to buy was the plug for the starter box battery.
One of the main things to look for is the balancing plugs. Seems like everyone has there own idea what the should be. The lipos I have for my mini's have different types than my HT Batteries and I can't balance them on my charger. If you already have a good charger then a balancing adapter is probably the way to go... You can look at my setup anytime. Hopefully I will be up sometime this week if it doesn't rain... Maybe Saturday. Ohh and I should have a body this week for you to paint as well.. Same as last year with a twist!!
