Old 04-01-2009, 12:59 PM   #1591
DC-Oh yea can't!!!!!...I hate indoor racing!Plus i think its going to be an awesome season...
TLR|Horizon Hobbies|SpektrumRC|JConcepts|BradleyRacing|92zero|VRP|AceHardware|Tekin|TXDGraphics
CurtDawg is offline   Reply With Quote
Old 04-01-2009, 03:59 PM   #1592
Chill_Will's Avatar
Trader Rating: 32 (100%+)
I'm with you on that with offroad and onroad.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 04-01-2009, 06:03 PM   #1593
Hi All,
Found the diff case along with gasket, at http://www.rcprocenter.net/servlet/t...-Gasket/Detail does anyone where I can diff gaskets on their own?
Also can anyone tell me if these http://www.rcprocenter.net/servlet/t...teering/Detail come with all the inserts, or do I also have to buy BB2050.
Guys are you using CNC or plastic chassie braces?
Let's share some tips like, Tony did in the past, come on guys.
Thanks for your help
Kim Jong-il
Jesussaves is offline   Reply With Quote
Old 04-01-2009, 07:21 PM   #1594
kamlooper's Avatar
Originally Posted by Jesussaves View Post
Hi All,
Kim Jong-il
Call RCProcenter, they can check the parts for you on the phone.
Yes it would be nice to have someone like Tony posting tips again.
kamlooper is online now   Reply With Quote
Old 04-01-2009, 07:33 PM   #1595
Trader Rating: 47 (100%+)
Well after my first run with the car at practice, WOW, what a well designed and built buggy! I have driven almost every 1/8 buggy out there and this one drives very well. Turn in is awesome! It is very stable and predictable and that was just the stock settings. I ran it hard all night and no breaks or hiccups.
I gotta give TQ Racing some props. The 2009 parts definitely make the buggy light on its feet and the tires I used had trouble keeping up with the acceleration this buggy produces.
I can't wait until next practice to try some things.
Kingsbury is offline   Reply With Quote
Old 04-02-2009, 08:21 AM   #1596
Send a message via AIM to smitty2802
Ok then when do we start??? i think the 18th will be my first race and i can't wait... i'm tired of the touring car crap... now it's time for the fun to begin
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 04-02-2009, 08:37 AM   #1597
Local racer's Avatar
Default Lets keep the team moving
Sorry I will keep you guys up on what we are doing,currently I am using the plastic brace combination.It seems to help the car on bumpy tracks,The big change we are seeing is with the 09 parts the car really spools up so we feel like we are getting closer on the acceleration side for the tracks that need more snap.
I will post our latest setup,it seems to work really well on all the tracks we have tested it on except those high bite oh tracks will have to ask Mr Curt May to help us with that.
Front
Lower Roll Center
Middle hole on top a arm and caster block
Caster 22 degrees
Front springs Jammin Blue
Front Oil 35
Front Diff 4000
Middle hole on tower outside hole on arm Full droop
Center Diff 5000
Rear
2 degrees ant squat for most out door tracks 2.5 if it is really smooth
Camber link lower hole on tower all the way in
furthest hole out on hub carrier
Lower mounting position on hub carrier height
Rear tower middle hole in
Rear Arm furthest hole out
Rear Tow 3.5 if low bite and big track
3.0 med bite med size track
Shock Oil 25 or 27.5
Stock Silver Spring
Rear Diff 1.000
We are using light shock oil because of the weather here if you are running were the temperature is above 60 to 65 degrees you can raise the front weight by 5 or 10
Local racer is offline   Reply With Quote
Old 04-02-2009, 08:51 AM   #1598
I will post my current indoor high setup later this afternoon,My car has been amazing!..
Old 04-02-2009, 01:08 PM   #1599
speedybill's Avatar
Trader Rating: 73 (100%+)
Unhappy
-DC-
OUCH!!!!
I hope your sponsor doesn't seez this LOL!!!
ROAR member #5-120259
www.speedybillsrc.com
www.ovrccc.com
Sweep Racing Tires
speedybill is offline   Reply With Quote
Old 04-02-2009, 02:06 PM   #1600
Default 1/8
Smitty I agree its time for some noise down action supercross style
Old 04-02-2009, 03:56 PM   #1601
Suspended
Trader Rating: 20 (100%+)
Where can I get the 2009 sx8. I want to try this buggy. LMK
bunnell33 is offline   Reply With Quote
Old 04-02-2009, 04:19 PM   #1602
kamlooper's Avatar
Luther has some kits coming. Give him a call, I dont have the #, do a search of his posts. It should be a great car.
Old 04-02-2009, 05:38 PM   #1603
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Hey Binky looks like you guys are really rolling on the 1/8th car.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-02-2009, 08:17 PM   #1604
I hear ya... i'm ready for some noise...
-DC-
Old 04-03-2009, 05:17 AM   #1605
Sorry guys it took so long,my computer crashed last night...
Front:
5 degree's of kickup-20 degree's of caster-Upper arms all the back-camber link middle on caster block-roll center middle(upper arms)-Stock pistons with 35wt(AE),ofna blue springs-shock mounting,middle on tower,inside on arm-ride height 29mm,ackerman is second hole back from front,-1 toe out,-2 camber,i limited the drop 3mm.5000 in the diff,Shocks built with 0 rebound
Center diff
5000
Rear:
3 toe,3 antisqaut,camber link is inside middle on tower,middle on hub,Shock:stock piston with 30wt(AE)Ofna White springs,middle on tower,outside on arm,limited the drop 3mm,hubs mounted in lower hole,hubs centered,ride height 30mm,-2 camber,diff 2000,Shocks built with 0 rebound
Note:this setup is with using the 09 parts,shock towers(F/R)Light weight F/R/C outdrive's,diff ring gears,cross pins,etc.I'm also running an OS Speed with alum clutch with 1.0 springs,stock gearing(Clutch bell,spur gear)
Hope this helps...
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
