Use WD-40 to clean your car or not?
#16
I have not had any problems using simple green, but I do not use it at full strength. About 50/50 simple green/water.
Denatured alcohol dries out plastics so it is wise to coat plastics with WD40 afterwards. I do not like D. alcohol.
I pull out the engine, radio tray, and fuel tank. Then its simple green + brush > hose > air compressor > WD40 > air compressor.
For the engine, clean it with a stiff brush. Plug the exhaust, carb, and fuel nipple (leave the plug in) > compressed air.
Radio tray and fuel tank.. I clean with a rag and a little bit of simple green.
#17
I take the big pieces off whole (tank, engine, front suspension etc.) spray them with WD40 then wipe clean with a rag. Never had a problem. Just take the radio tray off seperately and brush clean.
#18
thanks Nik
#19
just be careful not to get the wd40 on your brakes...i got a little on mine and it took a while for it to wear off enough to have solid brakes again...
#20
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
We use simple green + blow off with compressor, then denatured alcohol to de-slime + blow off again. WD40 on the "moving parts" like hinge pins, bearings, steering balls, etc.
#21
Simple Green
Looks like the majority suggest Simple Green to use first. I have never bought Simple Green. Does it come as a concentrated liquid and then you mix it? Then you let it set for a while, and then air it off? Am I still correct so far? And then last, spray truck down with WD-40 and wipe off for that "look like new" shine? Are my steps correct? Thanks guys. P.S.----Brake parts cleaner, is that basicly a no-no, not really necessary?
#23
I pull out all of the electronics and the motor then clean the motor with simple green and then spray the whole car down with simple green , scrub it then blow it off with an air compressor then spray it dowen with WD and let it seat over night . Your buggy/truggy will look brand new .
#24
its simple and its green!
#28
Registered User
Dont use WD40....
WD40 makes rubber go hard and shrink, its ok to clean metal parts but not anywhere near rubber, like bearing seals.
#30
