Tire Balancing???? >
Tire Balancing????
Tire Balancing????
Old 04-09-2008, 08:37 AM
Exclamation Tire Balancing????
i just got a mugen mbx5t prospec and wanted to know where can i get a good tire balancer from(website)
thanks
peter
playboy is offline
Old 04-09-2008, 10:31 AM
[email protected]
Machine's R/C H is offline
Old 04-09-2008, 10:34 AM
desertbird's Avatar
Once you have a balancer, what do you do to balance them?
desertbird is offline
Old 04-09-2008, 10:41 AM
Start the wheel on a slow spin and allow it to stop completely on its own. Take a piece of chalk or a grease pencil and put a mark on the tire at the highest point of the wheel (the zero degree position). This marks the lightest point of the wheel. The bottom of the wheel (the 180 degree position) marks the heaviest point of the wheel.
If you rotate the wheel 90 degrees to the right or left and let go, the wheel should move so the mark ends up at the zero degree position. If it doesn't, make a new mark and repeat.
Now you need to add some model clay where the mark is until you can move the mark to anywhere in the 360 degrees of rotation and have it stay where you move it. Keep adding until you find the right amount. Once you have the right amount of wheel weight figured out, mount it permanently and verify all is as expected.
That's it. It sounds a bit complicated, but after you have done it a few times, it will be easy to do.
Old 04-09-2008, 11:48 AM
Trader Rating: 19 (100%+)
Gene will that balancer work for the tr's 23mm hexes and all the way down to 10th scale truck tires also? I have been looking for 1 that will do all of my tires.
malik is offline
Old 04-09-2008, 01:49 PM
Yes, 14mm, 17mm, 23mm, 40 series, LRP, MTR, ect.
