Old 11-24-2007, 01:33 PM   #1
Default Engines and the Cold
So, I'm going to break in my HPI 3.0 engine now, using the heat cycle method.
It's getting cold here... 2C/35F.
I started it up once at home after warming with a blow dryer. It took awhile to start, so I imagine it's going to be really hard outside.
Any tips for starting in the cold?
I live in an apartment, so when I go out, I won't have a blow dryer to warm it up or anything.
What about after it's broken in? Will it be easier to start cold?
Any tips appreciated,
Woof is offline   Reply With Quote
Old 11-24-2007, 01:36 PM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
keep the fuel warm, and keep using a heat gun or hair dryer to warm up the block before starting...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 11-24-2007, 01:45 PM   #3
Well, like I said, I live in an apartment. So, I'd have to start it up at home, then take it all the way downstairs to outside.
Then how do I start it out there? Are there any cordless heat guns?
or I would have to leave it running at all times, so it never gets cold, but I'm trying to heat-cycle it.
Old 11-24-2007, 01:57 PM   #4
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
LONG extension cord, lol
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 11-24-2007, 03:14 PM   #5
Also, at what outside temperature would you say, starting becomes "normal" again.
Where you do not have to preheat the engine?
Old 11-24-2007, 03:48 PM   #6
A nitro engine will never be easy to start in the cold because the cylinder tightens as the weather gets colder - much more so than the piston because of the differences in the materials. So, heating it with a hair dryer will help, but over-cooling of the engine from too much cold air flowing will wear it out. Once you run in normal weather again, the fit between the piston and sleeve will be very loose. If you must run it in the cold weather, cut a piece of a sock or wrap some aluminum tape around the head to keep some heat in the engine. I've even seen an article where they cut some fins off the head for running in colder weather, then install a new head to run in normal weather conditions.
rcg33k is offline   Reply With Quote
Old 11-24-2007, 05:11 PM   #7
Trader Rating: 21 (100%+)
Send a message via AIM to shawnyd Send a message via MSN to shawnyd
anything over 50 and you shouldnt have to worry about it being too cold.
I ran aluminum foil on my engines to help keep the heat in. that way the cold air wont shock it as much...
shawnyd is offline   Reply With Quote
Old 11-24-2007, 05:58 PM   #8
big chris's Avatar
Trader Rating: 50 (100%+)
You need to find one of those hairdryers that plug into a cigarette lighter. Would that be closer to where you drive your R/C?
big chris is offline   Reply With Quote
Old 11-24-2007, 08:04 PM   #9
It's going up to 5C/40F tomorrow.
That's as warm as it's going to get for awhile here.
So, I think I'll try do all the breakin tomorrow.
I may just have to go up and down stairs to start/Run/Cool/Start again.
So, I've been reading that there could be a problem with breaking the engine in, in the cold.
When the summer comes around, there could be too much clearance of the Piston/Sleeve?
I have to keep it as warm as possible during break in and that way, it shoudn't be much of a problem. Right?
Wrap it with Tin Foil, etc...
Old 11-24-2007, 08:07 PM   #10
I don't have a car right now.
Old 11-24-2007, 09:02 PM   #11
pinky2252s's Avatar
being in the summer doesnt really have that big of an effect on the engines, thats why its easier to break them in, in the summer when its warm and its easy to start them and restart them
Team Terribles
Old 11-24-2007, 11:56 PM   #12
Mugen MBX-5's Avatar
as long as you keep the engine in doors, and heat with a hair dryer for a good 5 mins, it should be good to start when you bring it outside (unless your 200 floors up) my hairdryers max heat is you can put your finger right up to the exhaust and you cant hold it there it kinda hurts... see if you can do that with yours.
i just broke in a LRP .28 zspec the other day, i had the engine in a cold garage by accident, and i heated it with a hairdryer and it started first crack, yours should too, no problem. my temp is also colder then you, I was running it in -1 c, and the wind made it feel like -20
wrap tin foil around the head of the engine, and keep that tin foil on, theres no reason to take it off, you want the heat to stay in as long as possible, so bringing it inside, and leaving the tin foil on will guarantee it stays warm for at least 10 mins, which is perfect. if you let it sit outside, with no tin foil after running, it would cool in about 3 mins, and slowly ruin your engine.
make sure your glow plus is fully charged, im assuming you have the fuel inisde, and the engine too, so they should both be warm already.
also make sure to blow INTO the hose that hooks up from your gastank lid, to the muffler. take it off the muffler, and blow gently into it until fuel hits the carb (get 2 or 3 drops into the carb), and as long as its warm, the glow plug is charged, and fuels in the carb, you wont have ANY problems.
BTW, im assuming its a pullstart?? but we all know what happens when you assume...
Mugen MBX-5 is offline   Reply With Quote
Old 11-25-2007, 03:26 PM   #13
Good news. There is a power outlet right near one of the exits and a bench outside to setup on. Perfect.
I just ran it through 5 cycles. It runs pretty good, but will need some adjusting.
racing on cold day's Alltapdout Electric Off-Road 9 12-06-2007 01:43 PM
Hot or Cold Plug? Wyle E. Coyote Onroad Nitro Engine Zone 7 07-16-2007 07:45 PM
starting engines in cold temperatures... phillyfan5420 Monster Trucks 8 03-02-2006 04:23 PM
Cold Heat ZeroCooL Electric On-Road 62 01-10-2006 05:48 AM
Cold weather & Nitro Engines? Burnz27 Onroad Nitro Engine Zone 3 10-07-2005 06:53 PM
