Agama A319
#166
#167
Not super important however is it possible to get a few measurements??
The spacing on the tower or that piece that the lock nuts sit in. Cross pattern X or side to side, upper and lower hole centers.
I am tying to avoid buying a rear tower just for a hard template.
looking into making my 8ight use these mounts and incorporate adjustability.
Thank you so much for your help.
#168
Happy new owner of a a319 🤩
#171
I've done a lot of setup work over the past year and looking at the stock sheet I am surprisingly pretty close to what that says. I would start with the baseline but if needing to make changes the 4 degrees of toe in the rear is a lot i usually run 2.5-3. I run 4k in the rear diff to get a little more rear traction in the corner but know many people that run 5k. If you have any questions feel free to send me a PM.
#173
just popping in to say hi...
#175
Hi guys, does anyone know if agama shocks fit on other cars well? Id like to try them on another car of mine in the meantime before I get the kit. Or do you know the recommended shock lengths of front and rear? Thank you
#177
#178
How much faster are you with the 319 over the 215?
#179
What’s missing?
I’m
I’m
#180
nothing to see here, move along......
