Losi lst bottom plates
Hi,
I noticed there are two options for bottom plates. One is called HD and the other has cut outs. Apart from the HD having more metal over the mid are there any other differences, thickness?
http://www.amainhobbies.com/product_...Plate-LST-LST2
I like the one with openings, they will allow dirt to fall out.
i would say no thickness difference but the one without cuttouts would be stronger......
All are the same thickness and same material as stock. The HD offers more protection, the other is their "race" as they're lighter and both are obviously hard anodized. Losi also offers top plates that are hard anodized and also offered carbon fiber top plates and chassis. I forget the name but there is a full carbon fiber kit for the LST, chassis, top plates and all 3 skidplates.
yes, I've seen a lot of different plates over forum ant the net.
Thinking of gettting thos e"race" ones.
Another question, I tried the rpm arms I have today and it made my front toe out extreme. On further inspection the rpm a-arm is longer than stock.
Is that so, and if, then why, or did I get an monday-mold?
Not sure if I would still be able to have threads left for the tie rod. Never tried...
This was a surprise, I will email rpm and check.
Jsut a word on the skids - I wouldn't use the one without a cut out on the rear as I reckon it would 'scoop up' a lot of dirt.
I also saw a rear spefic HD plate. So many plates so little time
posted a pic in my build thread.
