Savage Flux HP Thread >
Like Tree7Likes
Old 04-10-2014, 09:32 AM
  #6856
rc_collector's Avatar
Trader Rating: 186 (100%+)
I can't find the vorza center diff in stock, any idea what other will work with the alza center ki??
rc_collector is offline
Old 04-10-2014, 01:04 PM
  #6857
Vitamin's Avatar
Hot Bodies Lightweight Center Differential Set 48T (HBS109836)
Vitamin is offline
Old 04-17-2014, 05:35 AM
  #6858
I got the vorza found it on ebay after days of looking, but good to know that one works too just in case.
thanks.
Old 04-17-2014, 09:41 AM
  #6859
Trader Rating: 14 (100%+)
Pretty much any 1/8 differential will work since race buggies/truggies are so similairly made between companies. I tried popping in another 1/8 center diff from a few years ago and it fit albeit not well because it was not 48t
RepEvox is offline
Old 04-17-2014, 02:07 PM
  #6860
werner sline's Avatar
https://www.youtube.com/user/SavageJunky
this guy realy makes me want to own a savage ! mad jumping skillz !! and very good explanations
werner sline is offline
Old 04-21-2014, 05:33 AM
  #6861
yup, saw that one, got a savage, and followed all the upgrades he suggested couldn't be happier so far it is the best bulletproof truck I have owned.
Old 04-21-2014, 07:53 PM
  #6862
any savage x owner or savage xl use could confirm me the size of the body
I tried to measure them virtualy !
i would like to buy of those body !
Old 04-21-2014, 08:26 PM
  #6863
21 inches or 54 cm is pretty close.
RepEvox is offline
Old 04-21-2014, 08:44 PM
  #6864
thank you
what about the width ? is the savage X body really 20cm wide?
Old 04-24-2014, 01:38 PM
  #6865
I didn't clarify, but I'm not sure how wide it is exactly. I had a broken XL body before and it's obviously wide enough for savages. I assume if your 54cm is correct then your width is also close.
I have a question for people running savages at this point in time ---> what pinions do you use? I will be running my truck here soon and I need some new pinions starting from 11t to 15t because I cannot seem to get them to stay on.
RepEvox is offline
Old 04-30-2014, 06:40 PM
  #6866
What pinions will fit with the 52 tooth spur gear? And is there a bigger spur available for the Flux HP? I have been googleing this stuff for hours...
I am wanting to get my truck pretty much as low as possible, but don't want to waste a bunch of money on gears only to find most of them won't fit.
The 20/44 is WAAAY to high. I have an extra 18 tooth pinion laying around, but that isn't going to be nearly enough.
Just as an example, I currently run my E-Revo with a MM2/2200 combo with an 18/68 setup and it's still geared too high for my use. I run 6S mainly because I have 10 3S batteries. I do like the higher voltage though because it's keeps things running cooler.
Art Henk is offline
Old 04-30-2014, 09:05 PM
  #6867
I don't think there is much room for a bigger spur but you can go with a smaller pinion.
Old 05-01-2014, 08:26 AM
  #6868
toronto_rc's Avatar
Why do you think 20/44 is way too high?
That's stock gearing on the HP with the cc 2200kv motor.
Perhaps you're using a different motor, larger and or heavier wheel/tire combo, binding in your drivetrain?
Is it a nitro conversion?
Comparing the pinion and spur with an e-revo won't be the same as a savage because of the different differential and transmission gear ratios.
If you're really set on getting the smallest pinion/largest spur combo, then you can use this calculator to get the same distance between the two gear shafts.
http://scriptasylum.com/rc_speed/gear_calc.html
toronto_rc is offline
Old 05-01-2014, 07:03 PM
  #6869
I am well aware that the Revo has different ratios, I was just stating that for people that are familiar with the Revo. While 18/68 isn't the lowest you can go on a Revo, it's fairly low. I plan to put a smaller pinion on it though too, even though temps are great on it, I just don't need that much speed. I have my radio dialed down from 150% to 100% on throttle, lol. I jump and bash my Revo and Savage, no speed runs.
Stock gearing on the Savage is just too fast for my needs and motor temps run higher than I want. Basically right now I am running the stock setup, but with an extended chassis on 6S.
That link you gave me is exactly the type of thing is was looking for. I was needing to know what would "fit". THANK YOU!
The stock 20/44 puts the spur and motor shaft at 1.06", or 26.99mm, away from each other according to that page.
A 12/52 combination also comes out at 1.06".
I plan to use the 52 tooth spur, but not sure if I will go as small as a 12 tooth pinion. Might just order a 12, 14, and 16 and see what happens.
Art Henk is offline
Old 05-04-2014, 07:42 PM
  #6870
Trader Rating: 69 (100%+)
Quick question for my fellow savage owners, I recently sold my nitro engine in my savage and now I'm going to convert to brushless. I already have a flux extended with flm chassis,now this one will be short wheelbase. But I'd like to do a tekin system t8 motor this time around, can someone please help me with some info on which motor mount I'll need ? Thanks
Mk3GinsterGolf is offline
