XCELORIN brushless?
Old 04-27-2008, 07:14 AM
  #16
speedemall's Avatar
Trader Rating: 60 (100%+)
The 9400 is waaaaaaaaaaaaay faster.As far as wire clean up I usually do the twist method on my servo and esc wires.I take a thin ,long screwdriver and wrap it evenly around that and it coils the wires making them retract tighter.I see your in West Virginia matt,Any dirt tracks out there to run these?I am about 20 minutes from charlestown.Have you been to the coliseum out here in frederick?Our track is indoor asphalt but I need some smooth dirt to run my micros in.We have ramps for the track but it's just not the same lol
speedemall is offline
Old 04-27-2008, 07:47 AM
  #17
matthewh's Avatar
na there is no tracks to run on around here. the closest one i herd is in pa. i've never been there though.. thanx for the tips though...
matthewh is offline
Old 04-27-2008, 07:49 AM
  #18
so who has a 9400 on a mini t? For those that do, is there any way you could clock the speeds it reaches. im lookin to get one but want to make sure that its lightning fast
OldSkoolSavage is offline
Old 04-27-2008, 07:55 AM
  #19
speedemall's Avatar
I had a mamba comp x on my mini t and it was so insane I had to sell it ,was to powerful and kept breaking itself.It was only fun in a straight line.You may run into the same problem but I guarantee......you will love it!!!!!
Old 04-28-2008, 07:19 PM
  #20
matthewh's Avatar
what is "sensorless brushless"? what other motors can i connect to this esc?
matthewh is offline
Old 04-28-2008, 11:33 PM
  #21
SN33KY's Avatar
so which is better?
mamba sidewinder combo or losi combo?
and does the losi one come with low kv's
because all i have seen is like 6000kv...7400kv and 9400kv
so whats the 6000kv like? similiar to the mamba 6800? or 5400?
SN33KY is offline
Old 04-29-2008, 06:50 AM
  #22
These are 280 sized, so they should have more torque than the mamba motors correct?
pinoyboy is offline
Old 05-01-2008, 08:25 PM
  #23
matthewh's Avatar
matthewh is offline
  #24
matthewh's Avatar
finally calculated the speed ..... 34.1 average.....7400kv 15/55 gear 1500mah....what should be next i want 40-45mph....should i go 7cell or 9400kv motor? if i keep it up i'm going to need new wheels....lol. what is the point in updating firmware of the esc?
matthewh is offline
Old 05-01-2008, 10:01 PM
  #25
SN33KY's Avatar
nah mamba's are same size...
SN33KY is offline
Old 05-02-2008, 08:20 AM
  #26
rocketron's Avatar
Trader Rating: 16 (100%+)
updating of the firmware can add new function, or options, or resolve problems. easier than sending back for updates.
rocketron is offline
Old 05-03-2008, 05:27 PM
  #27
MikeR's Avatar
Trader Rating: 15 (100%+)
No, Mamba motors are smaller, similar to 180's. The Xcelorin is larger - similar to a 280 as pinoyboy mentioned. Almost but not quite as big as a 300.
I just installed mine so we'll see how it compares to my Mamba 6800 smoothness wise. The programming card is pretty trick!
MikeR is offline
Old 05-03-2008, 05:50 PM
  #28
I can confirm too that they are slightly bigger
pinoyboy is offline
Old 05-05-2008, 11:09 PM
  #29
MikeR's Avatar
Well, mixed reviews from my system so far. The motor worked great at the races yesterday but the ESC had some issues out of the box. It was cutting out/ stuttering/ shutting down about 3 laps after charging the battery so I had to yank it out after even trying different things on the program card. Plugged the motor into my Mamba ESC and all worked fine after that which was enough to set TQ.
Am now trying to maybe update the firmware but the software has been very buggy as well. Installed software, then installed the driver, plugged in USB adapter and got the green light but when I launch the software it says it cannot connect to the usb adapter..... argghh.
MikeR is offline
Old 05-08-2008, 06:32 PM
  #30
MikeR's Avatar
Hey Ron,
Just tried the software and success! Last time I installed the software the wizard couldn't find the bridge driver off of the CD (windows xp). This time it found the software successfully.... weird.
Thanks for the help! Can't wait to try it again in a few weeks!
Mike
MikeR is offline
