Spektrum DX3R Setting Problem
Who know Spektrum DX3R Frame rate setting? Manual say digital servo must be used 5.5ms.
My problem is: if i use 1 digital servo and 1 analog servo, how i setting my frame rate? If i set to 5.5ms, the analog servo sound Z......Z......Z.......
but it write must be used 5.5ms.
Simple solution, just get another digital servo! Its never good to mix digital and analogue servos! With the DX3S/R, you're running a digital system thus its always better to run digital servos so that the signal pulses match.
