how do i set up a vega factory esc
my mate as got a vega factory esc how do i set it ? cheers
Initial set-up
Connect motor and battery to your "Factory" ESC. Turn on your transmitter and set all the throttle rates to 100%. Turn on the ESC at the switch. Press the set button once. The LED is on. Do not move the throttle on your transmitter. After a couple of seconds the LED turns off (neutral saved). During the next 3-4secs. move transmitter to full throttle, then full brake and then back to neutral. Now wait for 4 secs. while the ESC saves the radio settings. 3 LED flashes, signals that the settings are saved. The ESC is now set to your transmitter. if there` smoke turn it off & buy a MRT |
