Team Associated 12R6
#181
Hi guys, I just finished building my 12r6, it looks amazing. I am installing everything new, as I want to keep my 12r5.2 as a full running back up.
I always ran a futaba servo, this time I went with a mks ds9670. None of my servo savers fit this servo, anyone know what servo saver works best for the servo/car?
#182
The Kimbrough is too sloppy and will not give you quick or accurate steering on the Black Carpet. Overall the Kimbrough is just too soft of a servo saver for today's high bite tracks. Many of us have gone to the Tamiya Servo Saver and its a direct fit with the same design of the Xray springs but it fits unlike the Xray.
I recently ran an Associated 5.1 & 5.2, one with the Xray, and one with the Kimbrough - and honestly, neither had any slop. At all.
And then, I started running VBC 12M's - and again had two - this time one with CF chassis and one with Aluminum. One had the Xray Servo saver and one had the Kimbrough. After two years, neither had any slop.
Question is, where is the slop you're talking about? I've had both and both did their jobs perfectly... just wondering what you mean.
#184
It's not so much the slop as it is the holding power. Cut the car on and try to move the wheels by hand. The Kimbrough isn't as strong and will allow the wheels to straighten up in a turn when you have high grip. Over time the Kimbrough will get weak and have less holding power.
#185
#186
Nice kit! May have to try one.
#187
Just an fyi for those wondering about the xray servo saver. I put an extra stiff version in my R6 and it seems to be just fine. I have an mks servo mounted in front of the servo mounts. I have the saver mounted of the spline about 1/2 mm. Put a shim in between the saver and the servo. I also used the shortneck ballstuds. Pics below. I get plenty of steering travel, currently have it set at 22* on the outside wheel, but it can go more. It is about 15* on the inside wheel.
#188
I'm using the xray saver in mine as well. Works well, I found that just a bit of sanding on the ball cup mounting surface was needed so the arms are parallel.
#189
Has anyone tried the associated saver pn 8689? This looks similar to the xray at less cost. Looks like it may be a bit tall is all and may not work with the 12th?
#194
#195
Has anyone tried the carbon fiber chassis and rear pod?
