Xpress Execute XQ1 TC
#346
More of clearance above the upper deck... The wires don't even touch the body lol
Ok Xpress, we need a aluminium chassis and vertical upper-decks for Mid now!
#348
you can get split lower bulkhead for the xq1 soon, the rear bulkheads from the xpress ft1 when available will fit front and rear of the xq1 (was said in unboxing video )
#349
Low grip asphalt setup
I run on a parking lot and having issues with rear grip. Front is good, kind of over sensitive. Need to figure out how to make it more consistent and comfortable. I have the on power rear toe kit installed. Would this be part of the issue?
#350
Im not a pro but I remember something i learned that was important. If the front is twitchy and the rear loses traction early move weight back to solve the problem. But because the car goes from accel to decel you need to take that into account. I move my ride height a little but not much. What has been working for me is droop. Less droop in the front under accel means their is a big increase in load before the tires come off the ground. Mine dont come off the ground but the visual helps you understand how the weight moves slowly to the back when the front springs are helping and when the front springs are extended allot of weight moves back. The opposite is true on the brakes.
#352
Mid motor conversion
Any news on people running this?
#354
Thanks for that, what do you think of the car in general?
#356
The XQ1 Mid alu decks will be available in around 2-3 weeks. We have been busy doing FF things so it pushed manufacturing back.
#357
Any rebuild parts for the xpress DCJs yet ? Will the Radtec case work on the xpress joints ? Seems the xpress ones are always out of stock. The Yeah Racing ones are more money , are they any better.
