i have 120 $ to use on rcmart.com what should i buy
hallo i have just got my paycheck and i am going to use all of it on rcmart.com because i am ordering tires from ther to. but what do you think that i should buy i have a good radio, motor, charger, esc, car and body what more should i buy.
Many thanks from RAsmus by the way i am driving carpet electric 1:10
i have a good charger and i have good tools and i am going to buy batteries when the sommer seasson starts
any equiptment that is worht buying
Hey tlk to me on MSN.
As for carpet, some foams, The Fast Tyre foams for $14 for 4 on rcmart.com is a great deal. They should last you like 30runs so pick up 3 sets, for $42 you cant go wrong and will be set for a couple of months.
you could order some things like a selection of spurs and pinions, a few spare gears and arms etc. Finally, some bits and bobs like body pins etc
charles what are lathes and does rcmart have it
A lathe is where there is a lathe (of course ) which cuts a thin peice of copper off of the comm which makes the motor comm as good as new, this helps the performance of the motor as it keeps it in tip top condtion , i can't see a lathe on rcmart but here is one from rc mushroom and a few examples, lathes
Charles
Charles
ohh charles we have a couple of them in the club and one for club use that i could use in stead
Setup tools (Camber Gauges, droop blocks, & height thingys) would be good if you don't have them yet.
danjoy that is a good idea thanks
