The Drift Thread
#1186
Serandin - I was using an 8.35 FDR with my 5700 and it got scorching hot, but i wasnt using a fan.
sloshedmr_bones - Since you have invested in high powered brushless system, you should also invest in lipos mate. the mambas go off with lipo. I run a Mamba Max 4600 with an orion 3200 lipo, and it has about 3/4s the power of a 5700 on matched packs...
#1187
The heat problem will also depend on just how free your drive train is (take out the motor and spin the wheels they should keep spinning for prob 30 seconds +), your driving style, how long you run for ( if you're draining a whole 4800 pack without a break with any motor you're going to have major heat ), the ambient temp, the quality of wire you are using ( good quality wire is totally worth it ), your roll out (not normally an issue unless you are racing on foams, but a lot of drift tires are smaller in diameter than racing rubber and so should be taken into account), and prob a bunch more things that I can't think of right now.
#1188
I run my chassis in temps around 25-30 degrees celsius, so fans for me are a must. Im about to upgrade my standard bearings to acer's ceramic bearings. I was using 2 fans, but found that it decreased my runtime alot. Im investing in a 5v 40mm cpu fan and just mounting it with zipties to my upper frame. i dont run a heatsink, just fans. I do tend to run the 3200 right down to near cut-off, which is around 40mins. But im always stopping to check the temps and so on. if its a little hawt, ill stop for a few mins to get it down to temp.
I have also found that alot of other ppl are having heat probs with their mambas, my opinion though, since there sensorless, then they'll produce alot more heat. but someone please correct me if im wrong...
#1189
Drift Truenos
#1190
Ok so i am gonna replace everything part of it i am buying and castle is replacng the other. So should i invest in a heatsink this time around. How about these? http://www2.towerhobbies.com/cgi-bin...?&I=LXLKA2&P=7 http://www2.towerhobbies.com/cgi-bin...?&I=LXNDP1&P=7 http://www2.towerhobbies.com/cgi-bin...?&I=LXLNY7&P=7 http://www2.towerhobbies.com/cgi-bin...?&I=LXNPF9&P=7 http://www2.towerhobbies.com/cgi-bin...?&I=LXKVU2&P=7
#1191
Big event @ HPI's U.S. facility!
http://www.rcdriftclub.com/forum/viewtopic.php?p=14583
^^CLICK FOR MORE INFO^^
FREE HPI TYPE T tires for every ENTRY in class A or B!
SEE THE HPI SUPER TAIKU CARS!!!
HPI NITRO STAGE D DEMO!!
NASIOC CAR MEET
HPI will debut new drift gear that NO ONE knows about!
DONT MISS THIS HUGE EVENT!!
NASIOC CAR MEET
#1192
bodys
what car Bodies are you guys running?
#1193
Bdy 4 cr
Hey,
I'm not a drifter yet but I've been reading some of the stuff in here and watcjing vids on youtube and Realy want to get into it. I've got a Tamiya TT-01 (Brand new). no hop ups yet but want to get new motor, alum prop shaft, alum steering set, carbon upper frame and a blue neon kit to top it all off. One thing though, I've got the body that came with and cos this is the first on road car I've driven/bought I've scratched it up a bit practicing doing tight little maneuvers around cars/poles/fences/gutters cos theres no club near me (I live in Melbourne, Australia). Anyway I saw some of the pics earlier in the thread:
[img=http://img295.imageshack.us/img295/8387/drift034dh4.th.jpg]
(pg 30)
And want to get this body for my car (If possible). What make/brand (in real life) is it? And What model of car is it? Any way you get the "Drift". Oh btw can u get it Ready to role cos I can't paint?
(pg 30)
#1194
Check out: http://www.tamiya.com/japan/products..._rx7/index.htm
#1195
thanks. I think that my local hobby shop sells chassis for tt-01's cos they have a whole wall devoted to them so i'm sure that could find it there somewhere.
#1196
Hey,
(pg 30)
(pg 30)
#1197
NASIOC CAR MEET
NASIOC CAR MEET
#1198
nor-cal rc drift comptition
#1199
hi, i'm a noob in rc cars..can i know wat is toe in toe out, and wat is the perpose??and does drift car need to toe in/out? i'm setting up my tt-01 with pvc pipe( white colour), but does not drift well, its takes a very very wide drift, like flying out. and must i change the shock (using nor tamiya)? i'm using sport turned motor with 19T gear is it ok? txs
Check this out for setup info: http://www.drccentral.com/us/rcdriftsetup.html
#1200
that body belong's to friend's of mine. aries326 got mad props for doing that body , the design wa sbased on the regular rx7 (FD3S) that's in the D1. Anyways you cant get that prepainted like that unless you get someone to do it for you. and that body is the yokomo i believe. but just as pole_position said, tamiya already has a body very similar to that one with the TT-01 drift, including a light kit already.
