belt tips & methods
belt tips & methods
hi
i was just wondering if there is some belt tips for letting them last longer and stay new as long as possible?
and let them be REAL ONES PLEASE... not anything that will waste a belt and then you have to buy a new one because of some stupid jerk who told you a lie
so does anybody have any input???
If you've got to store your car for a long time, keep them soaking in WD40 before you put the car up. Also, never bend/crease them.
does that work???... thats only if im gonna store my car away for a while RIGHT
and oh ya this thread s for ANY kind of tips & tricks for belts
Actually that softens the belt so that there's 'less' resistence....
Another extreme way to reduce the resistence is to clip away alternate teeth... This tip from Japanese Magazine.
How to prolong belt life is proper belt tensioning.
how do i know if i am tensioning it properly???
when you say "less resistence" you mean like a smother drivetrain or freed up drivetrain? right?
but that doesnt mean that the life of the belt is prolonged... Right
I think the idea is that softer, more flexable belts hold onto the pulley more, they wrap around the pulley more causing more friction. A Stiffer belt has a tendancy to not want to grab onto the belt (not sure if I am saying this correctly) so you only need to make sure the belts are tight enough to not skip and you will have a car with a much more free drivetrain.
To make a belt last long is just common sense. Do not bend or crimp. Do not let the belt flip on the pulley or roll over on itself. Do not run them overly tight and make sure they do not skip. That's about it. Do put dressing on the belt or put WD40 on it. Leave it dry. WD40 and other stuff makes the belts softer because it breaks down the rubber causing the belt to fail prematurely. Some may say the if you don't put a dressing on the belt, it will dry rot. Well that is true but it will take a belt longer to dry rot than it will take WD40 to destroy the belt.
Originally Posted by koabich
Actually the WD40 trick does not necessarly offer less resistance but it does make the belts more flexable. If you notive the current trend is stiffer belts. The Tamiya "Low Friction" white bets are much stiffer than the stock bets. Schumacher is now back to the stiffer belt (at least when I ran the Mi2, people were not using the softer belt. Corally belts are pretty stiff as well.
thanks for the input
its a good thing that i wasnt gonna do that nor i am gonna do it now
i wasnt gonna do it because i alrady have a free drivetrian and well with your 2 cents i have even more the reason not do do it
so also what you are saying is that i shouldnt do anything to my belt...
just leave it alone and properly tension it
and oh ya any tip or tricks i can do so i can tension my belt it just right?
my manual doesnt say anything about the belt except for the installation
The belt should have slack in it. It should not be tight. The tighter the belt the more friction it adds to the drivetrain.
The general rule around my track is run the belts as loose as you can without them skipping.
My personal advise is to play with them and see what you like. If you want better throttle response, tighten them up a bit. If you want longer runtime and more top end, try loosening them.
so to get in the ball park you should try to get the belt as loose as possibe without it skiping and that should be the best way to prolong the belts life also?
