trf415 questions >
trf415 questions
trf415 questions
Old 12-10-2005, 08:25 PM
Default trf415 questions
hey guys just bought a 415 and need to know a few things about them.
Any parts prone to breakage?
How often do I have to replace belts?
Is it safe to run brushless in stock form and how quick do you think it will go with a Novak ss+ 8.5?
What type of gearing everyone is running?
Do they make a plastic bit to go over the top of the battery to hold it in place rather than Velcro?
Any hopups recommended?
And just give me your opinion on the chassis
Cheers,
Pat
*sil80* is offline
Old 12-10-2005, 10:13 PM
Burlap's Avatar
Post here dude:
http://rctech.net/forum/showthread.php?t=26996
Burlap is offline
Old 12-11-2005, 07:07 AM
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Any parts prone to breakage? no, its a tank, besdies the usuals
How often do I have to replace belts? not very
Is it safe to run brushless in stock form and how quick do you think it will go with a Novak ss+ 8.5? yes, and pretty fast
What type of gearing everyone is running? depends on the track
Do they make a plastic bit to go over the top of the battery to hold it in place rather than Velcro? what r u talkin about? u r supposed to use fiber reinforced tape
Any hopups recommended? msx conversion, if u can pop for it
overall is a great chassis. the only thing is taking half the car apart to get to theh diffs, and the msx conversion solveas that
Cheers,
Pat
hope this helps
geeunit1014 is offline
Old 12-11-2005, 08:42 AM
TENCHO's Avatar
i have been running my 415ms for over a year now and have only changed the belts once! parts that break...well if you tap a board at speed, you will probably bust a c-hub, steering knuckle, or front a arm. i have gone through many since i run on a tight indoor asphalt high grip track. i run a 5.5 gear ratio with a 23turn stock motor. (thats all they race over here in japan)
have fun with your new kit!
TENCHO is offline
Old 12-12-2005, 12:46 AM
thanks for the replies guys. how much is it going to cost me to get the msx conversion and any place you would recommend? im new to brushless so is there any type you would recommend?
*sil80* is offline
Old 12-12-2005, 01:52 AM
my local hobby shop has the msx conversion kit for 400aud seems pretty steep is there anywhere online i can get it from cheaper
*sil80* is offline
