TT-01 Forum
#1323
Its a HPI Racing Ford GT body 200mm, it stands out from the other cars when I'm racing. I like to be different.
#1324
#1325
Just a question
Hey i have been in electric touring cars for a while now, i currently have a yokomo ssg and wanting to get something newer but im not looking to spend a truck load, anyway i was wondering is the tt01 a good durable car and can it compete with other cars?
Cheers George
Cheers George
#1326
Cheers George
Cheers George
You would more likely compare your SSG with a Tamiya EVO5.
Kevin
#1327
Cheers George
Cheers George
#1328
TT01E Carbon Damper Stay (Front) OP1059 = 54059
TT01E Carbon Damper Stay (Rear) OP1060 = 54060
*Only M-Chasis Damper set can be used with this part.
#1329
Also, what is the deal where they say you can't use the adjustable rear camber arms with the rear stay?
If you still have them, is there any chance of getting a scan of the instructions that come with the damper stays? Currently, I am using the original combined stay and gear box cover with 3Racing CF reinforcement.
Kevin
#1330
Rather than buy a set of m-chassis dampers, do you think it's feasible to use 2 x rear damper stays? Would this give the same geometry as a normal kit?
Kevin
Kevin
Hi Kevin,
The CF stay sits lower thus making the suspension play length shorter. I dont think its feasible to use 2x rear damper stay as it would affect the geomentry / fittings. The single piece is strong enough to handle impacts. The only good thing bout the CF stay is that it has more slots and the suspension can lean at more degree.
I am using the adjustable rear camber arms now.
I dont have the instructions with me anymore but its very easy to fix on, just a direct replacement from the kit original .
Hope it answers your questions
#1331
Anyone using Yeah Racing ultimate Brainpower ESC 25A + 12T sensorless brushless combo with their TT-01 here? If not, any comments?
Thanks!
Thanks!
#1332
Hi Kevin,
#1334
yes, you can use the rear cf on the front. This way, you dont have to get the M chasis dampers but less slot for adjustment.
Damn, why didnt i think of that in the first place....
#1335
Awesome, cause im pretty keen on getting the rear damper stays to fit on my CF'd TT to complete it!!
