19t Info Needed
Originally Posted by Racer X
Been running races instead of racing them lately, but its time to get back on the track. In regards to TC carpet racing:
What is the hot 19t motor right now?
What are the brush/spring combos?
Thanks for the help...
I use Trinity XXX's and F Brushes with Purple+ and Purple- springs and roll them out between a 1.15" and 1.23" depending on track layout and size.
I have tried an Atlas and although it is a very good motor, it is hard for me to put a big enough gear to make it as fast as one of my C2's. I have gone as high as a 1.28" rollout and it still wants more.
TS
ive been running a Chamelion 2 armature with a 4 magnet can and its so F_*KING FAST in my tc3
so i would also go with the Chamelion 2 too
Give it a couple weeks and get yourself what will be the fastest 19t around....the new Checkpoint 19T will be here soon.Ive ran it against all the other 19T motors and i can assure you it is the best!!
in stock i have all sorts of trouble keeping my stuff on pace, but in 19T i run the Reedy Spec quad-mag, and never have any problems... the last 5 motors i've had, 1 pro version, 4 spec versions have all gone super fast with 767's and red springs... running 19T the motor is the last thing i worry about when trying to keep up...
Atlas is very fast and very impressive, C2 is also a really good motor. If you run a ROAR event run the C2 as it is approved.
Both are in stock at www.axiommotors.com and the C2 is on special right now.
