Tamiya TB-Evolution III
#6303
Stumper & Evo,
I think those thicker bevel gears could be produced by Xenon Racing, another hobby company from Japan, making these for tamiya as i got these gears from xenon themselves.
TRF drivers were driving their cars with much thicker gears, guys, these gears are real thick.
de xenon gears combined with the de new tamiya lite weight shaft work perfectly for my car.... u just need to add couple of shims on both end of the gear boxes....
i shimed mine as follows:-
front gear box
2pc x 3mm x 10mm on the "left" (pushing the one way out)
rear gear box
2pc x 3mm x 10mm on the "right" (pushing the diff in)
Note: directions "left / right": facing the gear box
Then you do the following test:
1) Hold down the gear and the left rear tyre
2) Push forward the rear right tyre
if your push moved the tyre with a "click" sound, then add another shim..... otherwise, you can't push the tyre at all, then everything's set..... let me know if how it works for u guys.....
godspeed.
front gear box
rear gear box
godspeed.
#6304
where would you buy those sort of shim sets?? also help needed. any tips for an understeering car??
#6305
can anyone tell me if there is a way to stop the wear in the cross joints of the dogbones and axles, or do you throw them away and buy new ones when there worn
#6308
Parts will wear out with use, can't avoid.
(At least you get 2 chances on the axles!!)
I've been using Tamiya TITANIUM grease in the unis, seems to
slow down the wear quite well - better than AW or Molybdenum.
My unis aren't visibly wearing out since I've done them. Every
rebuild I just flush them and regrease. Less drag than AW too.
#6309
My one-way gear is stripped....
Not REALLY bad (just enough to make a click in that spot everytime I roll the car)
If I just put some diff lube on the gear will it be okay for racing (will I notice a performance loss with a stripped gear?)
Yes or No would be fine...No resources with to replace the gear/shaft at the moment
Thanks -Dan
Thanks -Dan
#6311
hey i have a tb02 and was wondering if the EVO3 Blue Parts Conversion Kit is worth it for 150 dollars?
#6312
hey the black kat try shimming the gearbox. mite help alittle
#6313
It depends, because you will find that some of the parts are not directly compatible with the TB-02, namely the steering arms, the motor mount and the spur gear holder (although the later may be useable - I've not tried). If you also have an EVO III, then it might be worth it because then you can use the EVO specific parts as well.
#6314
Originally posted by racenut123
put the ball diff back in.it will continue to strip.
The thrust bearing on the original Surikarn diff is fizzucked & I put my "ghetto" front diff in the rear.
If I drill out the center hole bigger & the two screw holes on a regular diff gear will that work? I just thought of that a few minutes ago
Maybe I'll screw around with a spool on Saturday if I don't get anything flying
#6315
Not to sound like a meanie, but if you're running any car with bent hinge pins, a totally stripped front one-way gear, roached diff, a dud of a motor, and heaven knows what else, you won't be flying...No advice we give will help that.
If the front gear only has a few rough spots, you can clean them up with an exacto blade. It's not ideal, but it'll get you through a race day.
