Tamiya TB-Evolution III
#1546
u dont need to send spies into Tamiya to copy their design...it was released like 4 months earlier...
all u have to do is just buy a couple and start the Xerox process..
i do it all the time with assignments and reports
but as an afterthought ...i give credit to Yokomo for some of their innovations regarding the ease of removing many parts such as spur gear and steering arms.
more than once i found it too troublesome(ie i'm too lazy) to remove my beat-up spur gear.
#1547
SD copying the EVO3? Kinda like how Tamiya copied the TC3 design! haha.
#1548
Get a grip guys. Yokomo copying Tamiya. Tamiya copying Associated. Associated copying Tenth Technology. Yes all the cars have a shaft drive but there are differences in design. To an extent. I.e. the multiple camber link positions on the Yokomo c and rear hub carriers. Plus to each his own cause it's your money.
#1549
Originally posted by defMondo
The update is a metal disk and 4 screws which back the oneway gear, it's supposed to strengthen the gear.
Part number is EV0001 I think, Rainbow Ten usually stock it. I haven't seen it anywhere else yet.
Tony
Tony
#1550
Isaac, you gonna race TCS this July? I'll be up there. Just got back from Hanover. I was up in Laurel last year. Wondering if I should get a set of A's and B's for this July.
As for who copied who, just defending the SD since I have one on the way. I don't think you can stray too far from the typical shaft design. Only soo many ways to do it. At least the Yok has a nicer looking chassis!
Another note, I was told that Brushless motors are now legal in GT1 class. Might end up getting one this summer. Anyone have any pics of them installed on an EVO3?
#1551
Kilruf- I would just use the "B" for the TCS race. When it's hot those are the tires to have as you know. I might participate this year. The new GT3 class has me a little interested. That's all about driving in my opinion.
Nothing against who copied who it just that every industry does it. Its just who makes the best design or what you feel is the best buy. Heck I heard Losi may be thinking shaft. Rumor so don't quote me. I thought about the EVO III then I saw the Yokomo! I got a 414M and a TA04R so I was like I'll try the Yokomo.
#1552
Originally posted by theisgroup
di dnot see it on their site. do I just email them to order the part?
Tamiya should also be release a carbing fibre version which is in the Surikarn edition of the EVO3.
Tony
#1553
I've heard that the RED Edition is going to be VERY limited. Rumours are Rainbow Ten is only getting 10 kits !!!!!!!!!! Anyone else heard this???
#1555
Originally posted by Ralf
Yes that's true, Rainbowten will have 10 kits and 7 have already been pre-ordered.....
#1557
I just put together my TA04-TRF and interestingly enough it has a new front one way design that looks very much like the evo 3's except being anodize blue and it has an additional metal ring on the opposite side that serves as a support to keep the one way from warping which make me believe that this will be the fix for the EVO 3 one way gear issues.
#1558
E3!!!E3
#1559
What size bearing is on the bevel gear, part # 53066?
#1560
Also has anyone noticed that the front tends to bind? Is this the problem everyones been talking about? I made a backer plate out of carbon fiber to support the gear (instead of those tiny four screws included) I noticed as I rotate the wheels it was binding at a point -even with new gears. I realigned the front gearbox and it helped a bit, added two .07 washers between the upper two screws on the front gear box cases and not it seems freer.
