Awesomatix A800/A800R >
Like Tree2275Likes
    Hide Wikipost
Old 03-29-2023, 11:28 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800/A800R
Last edit by: hanulec
A800R Released March 23, 2023 with two kit versions, A800RA (alloy) and A800RC (carbon)
Mid Motor Content ---
New Part Releases
  • January 2020 - A800-AM24-20 Servo Holder - combine servo holder and steering holder to one single part.
  • February 2020 - A800-ADC Advanced Damper Cup Set - Reduces the amount of rebuild routines. It offers the possibility to A) remove air and B) add oil into the damper without the need of full disassembling
  • January 2021 - A800-BDL - Body Downtravel Limiter, replaces SPR08
  • March 2021 - A800-P138LFA - 38T Pully Low Friction - For Gear Diff
  • March 2021 - A800-P138S-LFA 38T Spool Pulley Low Friction - For Spool
  • April 2021 - A800-C27MMX - Full Length Top Deck for A800MMX
  • May 2021 - A800-C01MMA Alloy Chassis - Battery position is shifted to the front to achieve a better overall weight distribution. Removes short arm holes. New narrower shape
  • September 2021 - A800-C04M1+7.0 Arm - narrows the track width for lower grip levels
  • October 2021 - AM180EVO Single Bellcrank Steering Update - AM180EVO is a direct replacement for AM180M5
A800MMX and A800MMXA Kit Updates
  • AM152/AM24-8 is replaced by AM24-20 in this kit (UPDATE 08.03.2021)
  • P138/P138S is replaced by P138-1/P138S-1 in this kit (UPDATE 25.03.2021)
  • C01B-X-MMA is replaced by C01MMA in MMXA kit (UPDATE 26.05.2021)
  • AM180M5 is replaced by AM180EVO in this kit (UPDATE 21.09.2021)
Below OLD Rear Motor Content ---
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 04-04-2017, 02:24 PM
  #2431
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by v_squared
When will the next back of kits be instock again?
XAH in stock now at AwesomatixUSA
X and XA on order awaiting shipment...
hanulec is offline
Old 04-04-2017, 09:46 PM
  #2432
Trader Rating: 40 (100%+)
Default thanks
Originally Posted by hanulec
There are a bunch of hobby stores repping the car in North America
Jeff at ActivRC - California​
ademar at hyperhobbies - eastern canada
Mike at michaelsrchobbies - Florida
Alex at gripworks - western Canada
Danny at Apexrc - hawaii
New dealer accounts always welcome
Thanks , found almost everything I needed at Activrc......and the parts they didn't have they said they would place another order.
King of B Main is offline
Old 04-05-2017, 04:19 AM
  #2433
Can someone tell me the difference between P01/P02 and P18/19? There is a new spare part available that combines two parts of P18 and P19, bu the A800/A800X doesn't use them. Are they specifically for the old A700?
Rincewind is offline
Old 04-05-2017, 05:32 AM
  #2434
hanulec's Avatar
since 2013 we haven't seen a need for the p18/19. it was a smaller part possibly to use in smaller models -- say a 1/12th
hanulec is offline
Old 04-05-2017, 10:07 AM
  #2435
Does anyone know where to get an original lower aluminum chassis pt # A800-C01B-AL?
I have looked at all the usual places and no one seems to have one in stock.. Let me know if anyone has one for sale.
Thanks,
Brian
Aquaracer is offline
Old 04-05-2017, 10:15 AM
  #2436
hanulec's Avatar
Duh on last reply...
The khaki chassis are gone... Good luck finding a new one.
hanulec is offline
Old 04-05-2017, 10:46 AM
  #2437
A wee bit off topic, but I wanted to share a positive experience dealing with Awesomatix USA.
I ordered a few times with them, goods came in quickly and were well packaged. Last order, there was a little mistake. I contacted the folks at Awesomatix USA and I very quickly got an answer. While it ended up being fine ( I had ordered some carpet cut Montech bodies for Awesomatix and got XRay instead) as the XRay body would fit fine and would be better for my use, they immediately offered to make things right if I was not satisfied.
In this age of web stores, it is sometimes complicated to get good service. In this case, I can say I wouldn't have had better service in a brick and mortar store and that I'm very satisfied with the answers and service I got from Awesomatix Usa store.
Martin Paradis
rhodopsine is offline
Old 04-05-2017, 10:57 AM
  #2438
Trader Rating: 53 (100%+)
I order mine from ActivRC. They are very nice to deal with.
v_squared is offline
Old 04-05-2017, 11:06 AM
  #2439
If these are truly gone, what other parts would I have to order with a new A800X chassis plate to make an A800A parts work with it?
Old 04-05-2017, 11:26 AM
  #2440
geeunit1014's Avatar
Trader Rating: 14 (100%+)
To run an X chassis on an A car, at a minimum you will need the sway bar parts(p12x, ball bearings and the stoppers). I would suggest getting the rest of the parts (bulkheads, motor mount, top deck/st55) as well, as the chassis changes the handling quite a bit and the rest of the new parts help to work with it
geeunit1014 is offline
Old 04-06-2017, 09:54 AM
  #2441
Default Parts
Hi, I'm looking for part# C04M x 4 ... Anyone have any forsale ? Please send me a PM if you do .... Thanks
Old 04-06-2017, 10:47 AM
  #2442
duckman996's Avatar
Default Belt skipping noise
Big fan of this chassis and starting to have some success now that I have learned the setup mannerisms of the car.
On my mod car - had a funny noise under acceleration - sounded like a belt skipping. Was actually the center cog rubbing on the mount. Added more shims and she's good to go
duckman996 is offline
Old 04-06-2017, 11:12 AM
  #2443
I agree. I bought a used a700 car and was blown away buy the quality and design. No I have the new a800x car as well.
  #2444
celt's Avatar
Default AM87 Alu Bumper Brace
Gents,
The brace is threaded, so am I to understand that you somehow use a long threaded screw from the bottom of the bumper mount?
celt is offline
Old 04-06-2017, 11:52 AM
  #2445
OriginalDonk's Avatar
Trader Rating: 44 (100%+)
I'm currently less than enthused with my current car and am again flirting with Awesomatix. I've read through all posts since the XA and XAH were announced and am trying to work out how feasible it would be to bring an A800A up to spec with the XAH.
Anybody have that handy or is it time to dive into comparing the two manuals? I know parts availability is another consideration. Thanks.
OriginalDonk is offline
