Roche Rapide P10 1/10 200mm World GT Competition Car Kit
#76
So I hear there is a WGT-R car on the horizon, any truth to that?
Might explain why Roche USA hasn't had P-10 200mm in stock.
#77
#78
Anyone with a P10 EVO who modified it to run 2S shorty batteries? Parts, setup changes?
#79
It's been out for a little while now (got mine already!), but haven't seen the info on this forum yet, so...
New Roche Rapide P10 EVO 1/10 200mm Competition Pan Car Kit
- New design 2.5mm high grade USA graphite materials main chassis and rear bottom pod.
- New design graphite front bumper.
- New design 7075 aluminum motor mount / rear bulkhead.
- New design graphite top plate and chassis brace with “RFAS – Rolling Friction Adjust System”.
- New design quick center damper angle adjustment design
- New floating servo plate.
- New DVS-W big bore center damper, center spring, POM piston.
- New design 7075 aluminum front suspension mount plate.
- New black anodize 7075 aluminum steering turnbuckle (M3x30mm, M3x16mm).
- Wheel base adjustable (253mm-256.5mm). +/-2.0mm adjust from front lower aluminum suspension block. +/-1.5mm adjust from graphite front suspension mount plate.
- Caster adjustment : 1.8/3.25/6.15 deg
- 7075 aluminum bearing steering rack system design, more proportional and smooth steering feel. Quick adjust Ackerman.
- Low friction coating pivot balls.
- Front upper arm mount pin brace.
- Spring steel upper arm turnbuckle (M3x15mm).
- High grade composite front suspension plastic parts from Xenon Racing (Japan).
- Inline alignment battery placement. Forward/backward position selectable.
- 7075 aluminum easy adjust side spring holder.
- 7075 aluminum main shaft holder, precise adjustment ride height by spacers. +/-1mm forward/backward main shaft position adjustment
- Three angles pod link position adjustable.
- High precision ball differential and reliable carbon main shaft.
- Thrust ball bearing is included in ball differential with maximum performance.
- 64P 93T (16 balls) spur gear from Xenon Racing.
- All new aluminum 4.3mm reinforced ballstuds.
#83
I use .018" fronts with 1.25mm droop and 2* camber with 0* blocks with big shim back.
Stock side springs just touching with 5K grease in tubes. I changed center shock to an oval one I use, not sure of spring weight.. 2mm of droop.
For the rear I'm at 189mm wide, I did machine the hubs to fit the GTR rim better, the hubs are bigger diameter. While I was doing that I took 1mm off the face of the hubs to narrow the rear.
Battery full back and 2oz's of lead in the back.
#84
#85
R/C Tech Elite Member
my car is box stock + a few shims / front spring change. i too went to AE 0.018 front. i'll have to take a pic of the car. ran it friday night for some can-am rc series motor testing -- but i've forgotten the setup by now.
one thing to by the on the look out for is the need to add large amounts of weight.
also -- to run a servo saver!
#86
but as many of you know -- wayne is a mad man . i mean that in the best way possible.
I guess I'm Naughty by Nature...
#88
Here's another WGTR from our local track NORCAR.. "ROBERTO'S RIDE"
#90
