Old 09-22-2014, 08:51 AM   #1
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Default GT12 Racing
The BRCA rules can be found here. It is not a national class in the US, yet.
We will be trying the GT12 class in Madison, WI @ MARCCA this fall. There are technically 2 classes, but as the rules state: if there are less than 20 entries they run together sorted by qualifying times.
The 2 classes are GT12 Super Cup and GT12 Production Cup. Most if not all of us are going to set up for GT12 Super Cup (13.5 1S blinky with diff allowed). We've been making a lot of noise in the SupaStox thread as that seams to be the preferred chassis, but the class also allows Mardave and TIC cars. Rumor has it that Zen Racing will also have a chassis soon. Our club will also allow 21.5 2S to start with a change to straight 1S at some point.
Just so everyone knows what the costs are like, the chassis with tires must sell for less than 100 British Pounds (163.00 at this moment). If you haven't had a look please check out the SupaStox thread. You need a painted body, electronics and you're set to race. The diff makes rear tire wear very low.
The bodies are very realistic as are the tire widths and diameters making this not just a great racing class, but one that is fun to watch.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-22-2014, 10:05 AM   #2
Anyone have a timing setting for 13.5 1S on a Turnigy Trackstar?
Old 09-22-2014, 02:24 PM   #3
celt's Avatar
All the way up...grind...up some more.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 09-22-2014, 03:14 PM   #4
Nice! I did find a post saying that max timing is roughly 40*. I think there is enough motor there to keep up with the rabble.
Old 09-23-2014, 06:33 AM   #5
Can someone from the UK, who knows these things, comment on the various classes run with the Mardave/SupaStox I keep reading about?
GT12 - I know what that is and what the rules are.
Bangers - no idea.
HotRods - no idea.
Saloon Stox - no idea.
Transferred from the SupaStox thread.
Old 09-23-2014, 01:43 PM   #6
Don't turn it right up! These cars weigh 950g, or about 30% more than a 12th car. Go as high as you can without giving the motor a caning, and make absolutely sure the motor peaks out half way down the straight.
It is all too easy with these cars to wind them up and think they are going fast, when in fact all you are doing is piling heat into the motor. They have to be geared down in order for all that weight to be accelerated promptly and the motor to peak out on the straight. HTH
SlowerOne is offline   Reply With Quote
Old 09-23-2014, 01:58 PM   #7
I was thinking about setting rollout to 75mm and adding 1 timing mark at a time. I have the motor checker with, but even with a slave I'm not sure I'm getting real results when I tune the motor for 1S. I would think efficiency is efficiency at reduced input voltage. I'm replacing my Z3R as I'm trying to prove a point about cheap club racing.
Old 09-23-2014, 07:50 PM   #8
OrganicMechanic's Avatar
Trader Rating: 35 (100%+)
I started collecting parts today for the supastox to run GT12. Picked up four 13.5T motors in a cheap package deal: 1 used- Reedy, 1 used- LRP, 1 new/ 1 used- certified 5% D3.5s w/ 2 extra tuning rotors. I already have 2 Speedpower 6500mah 70c 1S lipos. Ordering a Trackstar GenII 120A 1S ESC soon, kind of annoying that the program card is only available from China...
I'm assuming MARCCA racers don't need to worry about the BRCA approval lists:
motor list
http://www.brca.org/sites/www.brca.o...0v6%20pdf1.pdf
battery list
http://www.brca.org/sites/www.brca.o...14%29%20v4.pdf
OrganicMechanic is offline   Reply With Quote
Old 09-23-2014, 11:06 PM   #9
Wink
motor list
battery list
If you think it's still in good sportsmanship, it should be alright.
Old 09-24-2014, 05:34 AM   #10
celt's Avatar
Nice second chassis John...seems to go just fine.
Stan Garvin
Old 09-24-2014, 07:07 AM   #11
Well the batteries are on the approved list at least.
The wife will be piloting the supastox, so it will be turned down to her comfort level. So the D3.5s shouldn't be a problem. I can't pass up a good deal when I find one, especially on my budget. I could put the Reedy Sonic in considering it's on the approved list, but it has a full season on it... Compared to the D3.5s were one is new, and the other only has Snow Birds on it in a 1/12th scale...
Old 09-24-2014, 10:07 AM   #12
The Sonic should be too. Tear it apart, clean the bearings and it's good as new.
Third chassis in the works, full upgrades and diff. Comes with an unpainted G903 (Audi) body.
Old 09-24-2014, 10:22 AM   #13
Last night I ran car 2 for the first time. Trackstar/Turnigy electronics and motor were very quick. A few quick tests on the motor checker to get the timing better and one gear change and off it went. Very quick on the straight! Came off at 117* after 8 or 9 minutes of nose to tail running with celt's car. I was not driving as my trigger finger may be broken, so thanks to Tazio Nuvolari for stepping in.
Old 09-24-2014, 10:41 AM   #14
I may do that to the Sonic, she doesn't need anything faster then that anyhow. So at what point does a motor need to be retired? any obvious signs? I recall reading somewhere about the magnets weakening with age or something like that?
Third chassis, nice! So you now have 3 supastox and Stan has 2 right?
If anyone comes across a used supastox for a decent price and doesn't want it let me know! I haven't bought a kit yet... try'n to do this on the cheap.
Old 09-24-2014, 10:44 AM   #15
celt's Avatar
Don't have my second yet...
Stan Garvin
