Like Tree1Likes
Old 09-29-2015, 08:01 AM   #1606
R Dodge's Avatar
Originally Posted by RioImmagina View Post
Well, i thougth that, with the 2016 model incoming, I could buy the 2015 for a good price 😌
For the time being, I don't intend to compete, just to have fun!
I see, then the '15 will do just fine.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 09-29-2015, 08:18 AM   #1607
Is there any parts that need to be bought together with the kit? Some unavoidable spares?
What kind of wheels? Foam?
RioImmagina is offline   Reply With Quote
Old 09-29-2015, 09:04 AM   #1608
Trader Rating: 33 (100%+)
I would get the same stuff.. mainly i would get a set of arms.. steering knuckles.. and castor blocks. maybe a spare spur gear.. couple pinion gears..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 09-29-2015, 09:32 AM   #1609
niznai's Avatar
Hello,
I'm happily running offroad outdoor with my Xb8e. Now that the season is about to end, i would like to keep driving indoor. The only nearby indoor club available runs 1:10 touring e-cars.
I'm highly satisfied with my buggy hence I would stick to xray.
After some investigation, looks like that the T4 is a most valid platform. But, compared to offroad, I had the impression of extreme complication, especially in terms of choice of electronics, rules, range of performance and tires...
My question is, would be the T4 suitable for casual driving? I mean, I would like to keep the wrenching time down to minimum and avoid to look all over for a bunch of hop ups part needed to drive straight...
You can see the track at www.arcb.ch
Ha! You're across the lake from Neuchatel. Can't see the track itself though, resolution not good enough. Been around there, didn't find the hobby shops, but I know a very good Xray shop near Zurich (well, about 1/2 hour on the train). Shouldn't be a problem with spares for you. Much better than here where the closest shop is in HK.
The thing with TC is the grip. There's much more of it than in offroad. Hence a lot of problems. A motor makes a lot of difference, setup makes a lot of difference, a tyre makes a lot of difference and so on. Hence the many rules and constraints. Much more fun I would say. When things work, that is. Not so much when they don't.
You'll be fine with the T4. Not much spannering to do if you don't hit things much, and even then, Xray is perhaps the toughest car on the market. Most of the spannering is going to be setup (if you care). Not if you don't.
Have fun.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-29-2015, 09:48 AM   #1610
Slapjack's Avatar
Trader Rating: 19 (100%+)
Originally Posted by KE4PJO View Post
#1. Yes to 2s
#2. Depends on your track size and such, I start around 3.80-3.90 FDR
#3. Hold on to your hat, they have lots of torque.
Ok, I just ordered the 1s. I am just stupid when it comes to gearing. What is the formula to use to determine the FDR? The car currently has 64P - 96T Spur on it.
Also what brand pinions do most of you use for 64P? Going off a recommendation of another member I was going to start with a 45T pinion. But I would like to know how to determine the actual ratio I am running too.
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 09-29-2015, 10:04 AM   #1611
Have fun.
Thank you niznai, I didnt think to the traction as cause of such diversity. Now I see.
Indeed in offroad I still spend a lot of time in tuning and wrenching (I love the stuff, yet it's very time consuming) but finally differences are limited. I see good drivers rocking with old and cheap equipment and bad drivers with state of the art stuff still very slow.
No real problems for xray parts availability in CH. And sometimes it worth to buy even oversea. Which xray shop close to zurich you're talking about?
Btw you can see the track in the promo video of the club in the welcome page. Looks small but nice. I'd love an asphalt 1/8 track, but there isn't...
Old 09-29-2015, 11:21 AM   #1612
KE4PJO's Avatar
Spur/pinion X drive ratio(1.9 for T4) = FDR
96/45=2.133 X 1.9= 4.0533
"If at first you don't succeed, sky diving is not for you" Unknown
"A bad day racing is still better than a good day at work" Me
KE4PJO is offline   Reply With Quote
Old 09-29-2015, 11:45 AM   #1613
R Dodge's Avatar
So Daniel hit on some things that you should look into. Arms don't really break much. C-hubs and steering blocks are usually the only thing that break and that is generally not a common issue. The c-hubs come in the kit as medium, though you may want to consider getting hards as they are a little more durable. The steering blocks are already hard in the kit but some extras of those are good to have.
The only hop-up I'd really recommend are the ECS. I prefer Xray because they don't force you to use a 3mm wide bearing like some of the aftermarket options do. IMO the 3mm bearing fails too quickly, so I feel the Xray ECS is less maintenance. However, the Xray ECS is generally 2x the cost of aftermarket options which is 1 huge selling point for the aftermarket versions.
You may also consider picking up some of the optional springs (comes with 2.5 front and rear) and the graphite arms. The car can be competitive on any surface with these options.
Regarding tires, I would imagine that would be determined by what your track/club runs. Most likely a rubber tire and they may spec a specific brand & compound.
Old 09-29-2015, 01:18 PM   #1614
good point dodge.. i completly forgot about the ECS shafts.. that is the first thing i upgraded.. my bad on that..
Daniel Grobe
Sponsors:
Old 09-29-2015, 01:20 PM   #1615
there is an app on the google play store.. called RC Final GearRatio that i downloaded.. it has the T4 in there.. so all you do.. is put in your spur, and pinion.. and hit calculate.
the thing about finding the right FDR for each track.. usually.. i just see what other guys are running.. and get mine in that ballpark.
Daniel Grobe
Sponsors:
Old 09-29-2015, 03:46 PM   #1616
Slapjack's Avatar
I'll deff check put that app thanks. There was a description I had read for one of the 17.5 short stack motors that said gear ratio should be between 3.2-3.7??
One other question I have. I bought this t4 off a rct member ad I was just looking thru the manual and noticed that there are no C hubs on the car for the ARS... Do those come in the kit or do you have to buy those as option parts?
Old 09-29-2015, 03:50 PM   #1617
Those come in the kit. Little baggy of parts..
Old 09-29-2015, 04:04 PM   #1618
Slapjack's Avatar
Yea that's what I figured...
Old 09-29-2015, 04:54 PM   #1619
Thank you guys, you're being most helpful.
Question: what is an ECS?
Regarding the wheels... I've read worrysome reports of rubber wheels destroyed in one pack and alchemy treatment to gain some grip. That's why I ask. Foam tires are very cheap...
Old 09-29-2015, 05:21 PM   #1620
Slapjack's Avatar
Tryin to figure out a couple things.
1. What is the purpose of this spec r upper deck pivoting ball system. It was on the car when I got it. But it makes the op deck arched instead of flat. What's the purpose? More flex?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
