trinity killshot 13.5 gearing
hey guys! need some help for 13.5 trinity killshot gearing. i'm running tc blinky and the track is aprox. 50x30 i have the purple and turquoise rotor. thanks!
We need a little more data - 50x30 - feet or meters? Tight layout or open? The more info you could provide about the layout, the better suggestions we'd be able to provide in return.
What is the motor setup. Torque or rpm. What rotor do you have. And in what car class, tc? Pan cars?
he doesn't say whether its the RPM or torque stator though. That will make a slight difference.
I'm going to guess it's in feet, because that would be an enormous track if it was in meters.
50'x30' would be a small track with not much of a straight, so you don't need or want to have too low of an fdr, unless that track has a bunch of very wide, flowing turns, but that seems doubtful.
I race a lot of 17.5 blinky and mod and I used to race 13.5 boosted, but I have not raced 13.5 blinky before, so I'll defer to others for FDR suggestions, but my educated guess would be around 4.5 and to use the turquoise rotor.
If it's a 50' by 30' track, I'd try a 4.7 FDR to start, timing at 50 degrees using the turquoise rotor. Should be a safe starting point regardless of the stator being used. On a track that small, I wouldn't consider using the purple (broadband) rotor, especially in a TC.
sorry guys. its actually 50x30 metrs aprox. its a big parking lot flowing track. stator is torque. i'm running touring blinky 13.5. i have both purple and turquoise rotor.
Try 4.3 gearing, 50 degrees of timing to start. Stick with the turquoise rotor.
