Old 05-25-2014, 09:13 PM   #1
niznai's Avatar
Default Xray gear diff O-rings
I have about three of these gear diffs and have noticed a propensity of the really thin O-rings to stretch to the point that I can't bloody put the diff back with the O-ring. What is going on, Xray?! It happens in diffs that use Xray oil or other oils (not that there should be any difference). Does anyone else have this problem?
And is the O-ring really necessary? The diff has a paper gasket like all other diffs which I imagine should be enough (didn't notice any difference when I run a diff without the O-ring). What is the point of that stupid O-ring that doesn't even stay put?
I think I just found another area that needs a little bit of optimising, Xray.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-25-2014, 09:22 PM   #2
klaymon's Avatar
Trader Rating: 71 (100%+)
I've never run an o-ring in any of the T4 cars I've owned and have never leaked a drop.
klaymon is offline   Reply With Quote
Old 05-25-2014, 09:37 PM   #3
niznai's Avatar
Thank you, I suspected as much.
Team Greasy Weasel
Old 05-25-2014, 09:47 PM   #4
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
I have built them without O ring with no problems. Otherwise you pretty much have to change the o ring with every rebuild.
mild seven is offline   Reply With Quote
Old 05-25-2014, 09:56 PM   #5
Odin544's Avatar
Trader Rating: 93 (100%+)
You've just discovered what most Xray users have known for several years. No O-ring is necessary. I would guess you don't follow the Xray threads? As this gets asked quite a bit in them.
I prefer to use a little green slime or equivalent on the paper gasket.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 05-25-2014, 11:37 PM   #6
niznai's Avatar
No, I don't really follow any particular threads, I confess. Nor does Xray it seems, since they haven't addressed the issue. So I feel I'm in good company.
Thank you for your input though.
Team Greasy Weasel
Old 05-26-2014, 04:15 AM   #7
Skiddins's Avatar
The O-ring, when fitted correctly (which does involve some luck) works fine.
The problem is not that it swells etc, but that part of it gets 'dragged' out of position as the two halves are gently placed together.
Like many others (including the team drivers it would seem) I just use the paper gaskets which work fine provided they aren't damaged etc.
Also make sure you tighten the screws diagonally and slowly to make sure it is tightened up evenly.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-26-2014, 04:32 AM   #8
niznai's Avatar
Thanks, Skid. I have built these diffs (from new) a while ago and just wanted to change the oil in one of them, that's why I took it apart and found I couldn't get the stupid ring back. Took out the others to check on the swelling situation and turned out they were too swollen. I had another two 'rings lying around collecting dust (new spares) so I chucked them in, but I won't waste any more money on these pieces of merde anymore.
The way I check the diffs are tightened correctly is by spinning them on a bearing. If they spin out of true, something's amiss.
Team Greasy Weasel
Old 05-26-2014, 08:38 AM   #9
Lonestar's Avatar
Niznai 1 - Odin 0
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 05-26-2014, 09:01 AM   #10
locked's Avatar
The o-ring isn't necessary, but I always use them anyway. They are a one time use sort of thing though. If you use them, use a new one every time you rebuild. I put it on the opposite side from what the instructions tell you. I find it stays put better that way while assembling.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 05-27-2014, 05:33 AM   #11
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
I had the same issue the first time I rebuilt a diff. A fellow XRay owner said "let me help you". When I gave him the ring he tossed it in the trash can. I rethought he was playing. He really tossed it. Never had any diff leaks since.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 05-27-2014, 03:10 PM   #12
malcnz's Avatar
I run a CSO and its a copy of the xray but better and you can get a whole bagful of orings...must be at least 10 in there for a few dollars and got them through RC Mushroom...but yeah the diffs dont leak without them anyway.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 05-27-2014, 03:41 PM   #13
F. Mendoza's Avatar
Maybe that is why you get at least 10 of them for a few bucks. Nobody needs, uses, or want them. You say so yourself, "the diffs don't leak".
PS - copies are just that, copies.
Old 05-27-2014, 06:56 PM   #14
malcnz's Avatar
Just giving an alternative as I could imagine the xray ones are expensive.
I guess a new car is always going to be a copy of something else but you get so much more for way less money than an xray and after a year of running its still as tight as day one
Old 05-27-2014, 10:48 PM   #15
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
if you need to reuse after it has swelled cut a small section out and ca back together works fine
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
