Will this body fit a ta06, tamiya says its 260mm wheelbase but fits 235 so im confuse
Please and Thank You. http://www.tqrcracing.com/shop/produ....asp?p_id=6785
The Porsche will not fit. That was made for the short wheel base TA03 called the TA03r-s. You can't get a TA06 that short.
I have that body, its a typo. The actual wheelbase is 237mm and as mentioned, was made for the short wheelbase TA03RS and TA03FS cars.
It is around 190mm wide.
You can use an FF03 chassis in the short wheel base setup, which I believe is 233 mm. Arm spacers can be used to get the extra 2 mm needed for exact fitment.
