Old 12-25-2013, 05:55 PM   #1
Default Will this body fit a ta06, tamiya says its 260mm wheelbase but fits 235 so im confuse
Please and Thank You. http://www.tqrcracing.com/shop/produ....asp?p_id=6785
Arsenal2012 is offline   Reply With Quote
Old 12-25-2013, 06:04 PM   #2
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Arsenal2012 View Post
If the ta06 is a 235 wheelbase it will fit. It says its for 235mm wheelbase cars. Doesn't mention 260 anywhere. I believe the kit it originally came with had a wide rear track so the body will be a bit wide for a 190mm TC n the rear. You could use wider rear hex's to space the rear track out a bit. I used a 1.75 mm shim on my T4 in the rear to make it wider for some of my USGT bodies.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 12-25-2013, 06:28 PM   #3
C5R01's Avatar
Send a message via Yahoo to C5R01
The Porsche will not fit. That was made for the short wheel base TA03 called the TA03r-s. You can't get a TA06 that short.
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 12-25-2013, 06:37 PM   #4
http://www.tamiyausa.com/items/radio...sche-911-49387
Typo????
Old 12-25-2013, 06:37 PM   #5
Typo????
Old 12-25-2013, 06:45 PM   #6
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
I have that body, its a typo. The actual wheelbase is 237mm and as mentioned, was made for the short wheelbase TA03RS and TA03FS cars.
It is around 190mm wide.
Dan is offline   Reply With Quote
Old 12-25-2013, 06:45 PM   #7
Dan
Dan's Avatar
Old 12-25-2013, 06:48 PM   #8
Dang I love the body type and whale tail thats to bad
Old 12-25-2013, 10:51 PM   #9
Trader Rating: 25 (100%+)
You can use an FF03 chassis in the short wheel base setup, which I believe is 233 mm. Arm spacers can be used to get the extra 2 mm needed for exact fitment.
iasca20 is offline   Reply With Quote
Old 12-25-2013, 11:14 PM   #10
Its ok im just not going to get it. Ill find something else, maybe a 997 or a GT3. But dang I really like the mid 90s porsche 911s
