Intellect Battery 3800
#181
Originally Posted by Danny/SMC
If they are peaking and not getting to hot then they are fine. The IB3600 is actually more like a 3800mAh cell and the 3800 is more like a 4000 cell.
If your GP3300 are only takeing that low of mAh while charging it means they have been used and not taken care of properly. The charge going in doesn't always mean that there will be more coming out under discharge.
My 3D Gallery Website
#182
Company Representative
What makes a good pack is a pack that runs strong on the track for the entire race. If you want to see what is a good pack without racing you need to cycle it with a high end charger/discharger such as the T-35.
A pack that takes more mAh while charging will most likely have more runtime but that is not always the case. When a cell gets older and the IR builds up in a cell that cell will take more mAh to charge because it's harder for the charger to put charge into due to the higher IR.
#183
OK thanks for the info Danny/SMC, i am getting the IB3800 and racing with 19t do you suggest traying to 0v or .09v with 6amp charge .03peak or traying to 0v and then dead short for the best preformance, what are your teamdrivers doing in 19t.
#184
Danny/SMC,
Would charging packs(IB3800) the night before a race and peaking them just before I hit the track ok to do? Whats the downside? Do I lose punch/runtime? I normally use my packs twice a day with atleast 1 hour rest before charging them again.
#185
OK-everyone-do you like numbers? Well-if these dont make your eyes open-then your dead.
I just cycled my deadshorted SMC IB3800 pack. These numbers are at 35 amps.
At 30 sec the voltage was 7.54, at 60 seconds, 7.33 and at 300 seconds-still 6.66.
Final numbers off the GFX??? 347 sec, 7.08 and 14.9ir.
Clearly the best pack by a huge margin I have ever cycled. I am not even going to bother cycling the other two. Holy Crap!!
Ray
Ray
#186
Ray
Ray
-Josh
#187
Originally Posted by danjoy25
Danny/SMC,
#188
Can someone please clarify the cycling procedures? I've heard so many different ways to tray them, charge them, repeak, all the nonsense. Can We just get three "official" cycling procedures for stock, 19t, and mod, please?
-Josh
-Josh
#189
try www.smc-racing.com
Danny at SMC has posted on here several times about the procedures for charging these cells, but they are also on SMC's website above.
Hope that helps.
Michael
Hope that helps.
Michael
#190
Thanks. I just remember seeing people post eight trillion ways they do it, and still getting good numbers. I just had no idea which way was the factory approved way. Thanks again.
-Josh
-Josh
#192
Hi Danny,
I just got an e-mail from a company called Intellect Brothers and told me they are selling IB cells. However, I found www.intellect-battery.com on the cells. Which company is correct ??
#193
I would charge at 6 amps with .02-.03 peak detect. If its real warm where you race use .02
Follow the guidelines on our website. You can deadshort your packs but I can't guarantee the long time effects on the IB cells since it's still a new cell.
#194
Originally Posted by LazyBug
Hi Danny,
Where are you located ?
Intellect Brohters is a reseller of cells and is not IB the factory who makes the cells. My understanding is that they don't get the top spec cells that we use for RC.
#195
can you define "long term"? are you talking about weeks? months? years? for example: im curious if i bring it down to 0.0v.. it'll only last (say) 6 months compared to NOT bringing it down 0.0v and it'll last 9-12 months? thanks!
- Chris
