lrp brushless esc
#557
kenneth
I think the heat sink is the same heat sink that comes with the set. you can either drill and tap the heat sink or you can use plastic bolt (like Novak GTB) that will be anchored in between the ribs. another option is for you to create the bolt boss using shoe goo.
#558
i have a lrp competition sphere and it shuts off under load,has anyone had this problem?i have sent in once and the new one does the same thing.as far as i am concerned the gtb is a far better esc,i have ran one all indoor season and havent had aproblem,the lrp has not even been in for one race.seems lrp should work on their quality a little better
#559
#560
flat oval track 200ft runline,4300 motor,2.55 rollout.also on same track i ran gtb,4 star lrp motor,1.75 rollout no problems at all.this is the second speed control just out of the box that did this.the winning car in 4300 was a gtb,4300,2.65 rollout and came off the track at 145 degrees
#561
Are you sure you didn't wire anything wrong? Any short? Once some wires were grounded on the chassis and the Sphere shut down as soon as I gave it throttle to prevent it from burning up.
I am happy with my Sphere.
#562
#563
adrian the motor came off at 155 degrees after 4 minute run.that is what we have been gearing the motors to come off of the track
#564
#565
I want one ...
How do you go about getting a a lrp brushless T-shirt ?
#566
is the LRP sphere comp and Vector waterproof?
I didnt want to use it in the rain the last time i ran it as i wasnt sure?
#568
Would it gain any benefit if I replace the stock capacitor with a higher voltage one ? i would run my Sphere competition with 4 stars on a touring with Lipo .. if so, do I need to solder off the stock one or ...... ??
Pls advise, thx in advance
#569
Originally Posted by azmio
kenneth
Where can you get the plastic bolts??
#570
Trader Rating: 22 (100%+)
I wouldn't use plastic bolts unless they have threads to go into. Plastic bolts can usually be obtained from electronic part retailers.
