New VBC Flash-04 F1
#63
I got my kit today as well as all the other bit I was waiting on for it. Still need to glue tires up and paint the body.
I used the Speed Passion body and I had to move the rear body mounts inboard to get it to fit.
Uploaded with ImageShack.us
#65
Sure!
There just phone pics so bare with me here
A couple of things to keep in mind.
- The biggest pinion I could fit on the stock spur with the axle in the lowest position was a 35t 64p Which gives about 2.71 FDR
- The F104 wing needs a bit of trimming around the mounting hole to slide into the front suspension block
- The full aluminum rear pod is dope!
#68
I'll be working 9 12.5 hour night shifts in a row starting today so It wont be for a while. I'm anxious to get it out there and throw start some setup stuff.
Here is what I'm starting with
- black front springs
- black rear pod side springs
-5.5mm chassis ride height
-rear axle in lowest spring
-red kit spring and kit oil
-2.5 negative front camber
-10* front caster
-.5* toe out
-10* front caster
-.5* toe out
#69
Has anyone else built the ball diff on this thing yet? Is there a bearing I can use in place of the plastic bushing they include to fit the spur to the axle? I feel like the plastic bushing is causing some binding that would affect the performance of the ball diff.
Anyone?
Anyone?
#70
Anyone?
Anyone?
#71
The plastic piece in the spur gear is an adaptor. They did this as there are a large number of inch (3/8) bore spur gears but the axle is 6mm. As far as I know there isn't a bearing that has a 6mm i.d. and a .375 o.d.
Our club got 4 kits and so far one adaptor fit the axle well but not the kit spur (gear bore was undersized) and the other kit the adaptor was very tight on the axle but loose in the gear.
