Tamiya TA05 Touring Sedan
#3166
I'm placing my order tonight and will have it by next week
You just have to know where to order
Originally Posted by speedemall
when is the release date for the 05 chassis?
#3169
Putting my TA05 together, I noticed a problem. I am using universals and it seems like the dog bones are too long and it will effect my ability to adjust camber. Has anyone else had this problem and how did you fix it?
#3171
Thanks. I have 48mm with the stock suspension.
#3173
i got the 46mm universals and fixed them in my stock ta05. but i found that the stock plastic wheel hubs were touching the outer bearing when the wheel nut's fully tightened, causing a slight bind, enough to stop my one-way's from spinning freely with a blip of the throttle. anyone experienced the same problems? or am i doing something wrong?
actually i already solved the problem by getting the aluminium wheel hubs, so just wondering why the stock parts couldn't fit
#3175
#3177
Might be an overkill, but what I did was to install the 48mm shaft to the optional CVD for the TA05. Just looks better with the blue
Oh, by the way, I removed the red foam spacers or else it will be too long.
#3178
Originally Posted by DA_cookie_monst
No, not overtightened, the pin drive must be slightly closer in on the CDV axle than on the stock axle, only slightly, which means that when you tighten up the wheel nut, the hex fouls the bearing.
#3179
Spares...
hey guys.. i have a lot of spare parts for sale (old suspension) for the TA05. there's a link in my signature.. or you can visit:
http://www.rctech.net/forum/showthread.php?p=2174251
if you hurry.. i can ship these out tomorrow morning!
